I'd swapped some up front before tearing in, and all seemed well. However, this was when I had been told by a shop that it was #3, a rear bank coil, that was the issue.
This afternoon, I started her up and gave it a few minutes. Disconnected each of the front bank coils individually but didn't notice much of a difference at first with only one disconnected. HOWEVER, I confirmed that all 4 are good, at least from a cold start, by disconnecting #5, then also #6 - drop in rpms is then obvious. Reconnected #5 and the rpms go back up --> #5 is good at that point (un-warmed-up motor). Then with #6 still disconnected, I unhooked #7 - another clear drop in rpm. Plugged #6 in and rpms go back up --> #6 is good. Did the same with 7 & 8 (used #5 as the secondary unplug for #8). Plugging #5 back in, I did notice a slight uptick in speed.
I think my plan now is to just get the 8 damn coils and plugs in and reassemble. If I still have issues, is it fair to say it's gotta be the injectors? If so, I'll have the pros do that, though I guess it would be a great opportunity to get a feel for the work. I'll just bring them the LIM with fuel rail attached and they can put in the elbow grease.
QUESTION:
I had a thought while driving into work earlier - is the signal to the coils too sensitive to splice in a disconnect to those on the rear bank? It's easy to disconnect the front while motors running, but not the rears. I just thought it would be nice to have the ability to disconnect the rears on the fly for diagnosis, probably crimped quick connects with some dielectric grease.
