High Pressure Fuel Pump Revisited
Vigilante
Texas
So checking Livernois' website I noticed that the High Pressure Fuel Pump for the SHO's is now available. So I called them and spoke with Scott. He informed me that this fuel pump will run using pure E85 but will still not attain maximum horsepower possible. He advised they have added a severe Firestorm kit which with the High Pressure Fuel Pump will attain even more horsepower using E85. The cost for this severe Firestorm kit is an additional $1000. So to those who have purchased the High Pressure Fuel pump what results have you achieved as far as additional horsepower is concerned? Are you using straight E85 or a mixture of 91/93 octane and E85? Are any of you using the kit described by Scott? Thanks
xFallenxCripplex
What's the drivability do you have to gun first gear
BamSHO
South Williamsport,PA, US
OK, first to run straight E85, you WILL need a boost pump to turn up the volume on the in tank pump. Also if you have a 10 thru 12 car, you WILL need injectors, 2013+ cars so far dont, plus I don't think Livernois is remote tuning cars yet with the bigger pumps yet. You are looking at least 4 to 5K to go this route.
bpd1151
Lurking Around
SHOcago 'Burbs
Accurate info..... and I will reiterate, focus on the "AT LEAST" amount quoted above.
One can buy A LOT of Methanol for that $$$ investment. Geezuz.
