stlwhitesho
I've had my sho for a while. 13 Upgraded dw300 lpfp,xdi vo hpfp, dp, on e30 and meth. Car has ran strong for 4 years with good maintenance. Recently I had a low pressure fuel code and car stalled. It wouldn't start at all. I swapped the fuel control module first and nothing. So I swapped back to the old module. I ordered a new dw pump and a bucket from rockauto. Installed the pump and plugged everything back in and made sure the connections were good. Fired it up and ran fine for about a mile just cruising. then a studder. So I get the same low pressure code now and a evap pressure to high code. Checked low pressure and I only get 30 with key on but car off. All I can think is faulty bucket somehow, shit install evethough it is pretty strait forward and the first one worked in the modded stock bucket for years. Or maybe the module is bad too somehow and I should try it again and hope lol. Thanks for any imput.
