Thinking about doing ball joints & SB links
98SF19
AlphaKennyBuddy
Florida
. . . but I don't own air tools. I know they make all medium to major jobs easier, but as for ball joints and sway bar links, is it a bit foolish getting into this job without them? Need to do these before Konis go on.
Father's Day is around the corner, so dropping hints may yield the tools I need. :rolleyes:
98SF19
AlphaKennyBuddy
Florida
*Kids don't read my post*... :p
:laughcry:
Seems like, at a minimum, having a breaker bar, c-clamps, a rented ball joint puller kit, and maybe a vice-grip are needed.
I think I'll just roll up my sleeves, grab my nuts, and get 'er did.
98SF19
AlphaKennyBuddy
Florida
Hitting some snags and haven't even gotten started. You'd think ACE hardware would have a 1/2"x3/8" socket adapter right? They didn't, nor did they have ANY socket adapters. It was quite befuddling. Found one at Advance though. Also had to take car to my mom's garage to avoid upsetting retired old fart neighbors who frown on anybody doing car work in their driveway . . . deed restrictions suck.
Anyway, question: Do the center caps on the stock Gen 3 wheels pop off with lug nuts still on?
It looks like they can, but I wanted to be sure before prying it and possibly having it crack. They are over 19 years old now. I'd considered saying "screw it" and just prying away, thinking if it cracked, it might be a good excuse for getting new wheels (and tires) to accommodate larger breaks. But I have enough to deal with doing the suspension, so I'd prefer to keep it clean for now.
FYI, I DID get a nice Ingersoll Rand air tool set for FD, but as I don't yet have a compressor or hoses, I'll be doing the job without them (hence the need to get 30 mm spindle nuts loose with tires on the ground)
Do I really need new 30mm spindle nuts and castle nuts as the v8sho write-up states?
gamefanatic
Barstow, CA
It's recommended to get new 30mm nuts, but I have rused them with years of success. I am sure it has something to do with how much they have to be torqued. The castle nuts will be fine so long as they are in good condition...
The center caps could come off, but just depends on how much they bind against the lugs. They aren't technically held in by the lugs.
98SF19
AlphaKennyBuddy
Florida
Considering the age of the wheels and that I'm in a high UV part of the country, I wasn't comfortable prying too ******* the caps to get them out. I wound up just removing tires and popping cap out from the back side. But then I had to put tires back on the car for . . . the spindle nut . . .
My breaker bar's only 18" long, maybe a bit more. I put the 30mm socket on and not only stood on the end of the wrench, but BOUNCED a few times - no dice. That **** is ON there. Sprayed some penetrant and that was 2 days ago, so hopefully this weekend will be a different story, and I do plan on putting an iron pipe over the wrench handle. I don't think they've ever been off. I think you're right about the high torque being the reason the nuts should be replaced. Anti-seize applied upon reassembly might allow future reuse.
stephen newberg
Ladysmith, BC, Canada
LOL. I used to use a long chunk of 2" iron pipe. Maybe 4 feet long. Had it spring back at me once. That hurt. It was long ago. Now I tend to let the more nimble younger guys at AutoCheck do it when things like this come up. Just call me chicken shins... ;)
pax, smn
98SF19
AlphaKennyBuddy
Florida
I'm midstream on this job, and more than any other time since I've owned the car, I can say THIS FREAKIN' SUCKS! I really shoulda waited till I got a compressor to go with the air tools before getting into this. It's proving to be a *royal* pita with hand tools. Even with the breaker bar AND floor jack handle for added leverage, removing the spindle nuts was a CHORE the whole way off. When each one finally came off, it was too hot to hold for more than a couple seconds as a result of the friction. Are the spindle bolts (threading) replaceable apart from the whole shaft? I didn't see much oxidation, but I guess over time, the material began to pit.
Then there was the sway bar links - holy SHOOT dude. Whereas the spindle nut removal allowed for 180+ degrees of rotation with a breaker, the sway bar locations allow very little room, unless you're using a stubby wrench, which wouldn't provide enough leverage. Once I discovered that I could put a crescent on the top inner sbl nut and use the strut for leverage, those were done. But the bottom sb nuts were the same as the spindle nuts - hard cranking the whole way off (lying on my back with a foot up in the wheel well, trying to stop short of getting a hernia). It almost seemed like they were cross-threaded, which they may have been - couldn't get nuts on cleanly afterward. The passenger side was especially nasty. Is this an indicator of sway bar links that have been on too long? The next hurdle will be how to remove the passenger side pinch bolt which appears to have been rounded off, most likely by the shop that did transmission rebuild. Not sure how to go about that one. Suggestions are very welcome . . .
Sorry for the book!
98SF19
AlphaKennyBuddy
Florida
Oops. My rant was misplaced into another thread . . .
Re: ball joints, I think I've found the best solution for ball joints that don't want to come off: The Harbor Freight jaw clamp. $14. I also bought a pickle fork but as the first one worked very well, I might just take it back. The good thing with the jaw clamp is that, with the right prep (gently wedging rubber boot up and away from control arm), you can actually save the ball joint. There's a great video on YouTube where a guy tests it out, the main take-aways being to **** the bolt before using the device, and also not to try to pop ball joint loose with the device alone, but to crank the bolt down a bit (+/- 30 ft-lbs), and if THAT isn't enough to pop it loose, whack the control arm right next to ball joint. This was the answer for me. Came off with 2nd hit (wd40 played a role as well no doubt).
Getting hub bearings free of knuckle (after removed from strut) was a different story. Basically just set knuckle on floor with lug bolts down, sit down with strut pinch bore toward you and a put hooked end of a pry bar into it, resting other end against left side of your torso. Start breaker bar with handle pointing left and pull it toward you. Just like the sway bar links and spindle nuts, it took some torque to get them off, not just loose. I noticed some blue stain on bolts after removal, but surely the blue Loctite would have required much more than hand tools could provide. I think these were original bearings and considering how stiff they were, I expect to get at least 1 or 2 mpg with new ones.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
the spindle nuts need a good friction fit to prevent loosening, the outer lip has been swaged (bashed) to push it inwards. that's what provides the friction to keep it from backing off. hit them with a big punch or something to keep that big dimple.
using a 3/4 drive socket and breaker bar really helps in extreme torque situations, you don't waste any torque bending the bar.
on the rounded off pinch bolt,, if you elect to drill it out start from the back where the threads are. begin with 1/8" and go up in steps.
when the head of a bolt is twisted off it creates hard and soft areas in the shaft. while drilling by hand the bit will follow the soft routes and you get a crooked hole.
that results in only half of the bolt being drilled out, and usually too much of the knuckle threads being destroyed.
EDIT
oops, it was a little too late in the evening when I typed this.
this applies to the 89-95 SHOs that have threads in the iron knuckle. I kind of forgot the 96+ has a nut & bolt thru the aluminum.
98SF19
AlphaKennyBuddy
Florida
Turns out the rounded off pinch bolt head was a non-issue since they have a hard set keeper tab, so the only critical part was the nut, which was in good shape on both sides. It was actually very easy getting it off. But I appreciate the info on spindle nut and materials science - I may very well need it in the future!
Now I'm looking to get Gen 3 SLO strut housings on the cheap as the user who sold me the Konis sent them with Gen 2 struts (which have a different sway bar link bore geometry). Wish I'd have know this before I cut one down . . . :bonk:
98SF19
AlphaKennyBuddy
Florida
2 questions:
1) Is there anything weird about removing control arms? The rear bolt looks accessible, but for the front, there's just a bolt coming through subframe with a nut. Is there anything special about this with removing or reinstalling?
ANSWER: nothing special about them other than driver's side front - you have to remove the 2 15mm bolts from the tranny mount just inboard of strut, then jack up trans about 1.5", or however much it takes to pull the front bolt up and out.
2) Same thing with removing ABS sensor on the knuckle (held on by 1 torx head screw). The ball joint replacement write-up on v8sho says nothing special about this, but I remember reading one users write-up and it mentioned leaving something attached since parts popped out when removed. I can't find the latter, so I'm not sure if it was talking about the same thing.
ANSWER: nothing special with these either - I did buy a set of external torx sockets to be able to reuse the same bolts to reinstall sensor.
98SF19
AlphaKennyBuddy
Florida
Good Lord I am running into snags at every turn. So it looks like the ebay user who sold me 1 LEFT strut assembly, and 1 RIGHT, actually sold me 2 RIGHTS. Before I contact them, can someone confirm this? Pics of trimmed strut housings are here:
https://www.dropbox.com/s/3lzx14dy4mahfh1/Taurus SLO struts 1.jpg?dl=0
https://www.dropbox.com/s/onzjf9chh4nvsk6/Taurus SLO struts 2.jpg?dl=0
I'm most concerned about the geometry of the sway bar bore plates. Seems like they should be symmetrical since sway bar links connect from rear on both sides (as my original SARCS' are). The little ****** piece could be ground off I guess. I also notice that the springs I have ARE symmetrical as well, IE they spiral the same way.
I also had to order a 1/2" chuck to mount to 3/8" drill (no local stores carried one and I wasn't about file out a 1/2" hole in bottom of strut for fastening bolt), and that's another 4 days of waiting. So I'm hoping to get strut issue resolved in mean time.
98SF19
AlphaKennyBuddy
Florida
Updating as I go . . .
Turns out the SLO front struts are identical, which I determined based on the imprint left by upper sway bar bolts and nuts of the vehicle it was on before (size varied for bolt and nut).
Got all parts painted (will post pic of all parts later), but I was amazed last night at how easy it was to install ball joints into knuckles. After reading all the non-sense from years ago about the best way being to put knuckles in oven and ball joints in freezer and such . . . that's for the birds! I was able to use the ball joint tool c-clamp and got nearly the entire thing in just by turning the threaded shaft with my hand. I had cleaned knuckles thoroughly for painting (taped off all bores) and I used Motorcraft ball joints, so maybe those make a difference. What took a while was the retaining rings. Finally realized I could use needle noses along with other pliers to set a gap while I wiggled it down and into the slot. See pics.
Waiting for cut-a-strut allen bolts and washers, then after getting strut assemblies put together, I'll be on the final stretch!
BALL JOINT INSTALLBALL JOIN RET RING 1BALL JOIN RET RING 2
gamefanatic
Barstow, CA
Yeah, they shouldn't be hard to get in. Just hard to get out. Of course if you are worried about doing that again, best to use some sort of antiseize. Nice paint job, did you do that your self or get someone to do them?
98SF19
AlphaKennyBuddy
Florida
Did the paint myself. Took a while considering I did several coats and 1 or 2 coats of polyurethane or enamel. I had briefly considered sandblast/powdercoat like the valve covers and intake, but didn't want to be running all over town or spending much more $$$ - it's been hectic enough with issues popping up, the latest of which are a dead battery and the driver's-side spindle which seems to have had the smooth non-threaded end segment (1/8" +/-) threaded in a way that doesn't allow getting the nut back on. I blame high heat resulting from the amount of friction during removal of nut - apparently the shaft expanded more than the nut causing the nut to leave a threaded groove in this region. My solution will be to file down just this small area. I just hope to heck that the entire length of spindle threading isn't shot from some schlub slamming it on cross-threaded with an impact wrench. As for battery, that one's squarely on me. Had a 1.5 amp smart charger going from early on, but assumed that the radio unit I had put back in was the good one. Nope. It was the one I had removed a while ago due to a parasitic draw. The 1.5 amps couldn't keep up and when I checked battery, it was down to . . . 8 volts. Had it tested and 2 cells were dead. The weird thing is that the charger was showing fully charged for a while, and I only discovered a problem when trunk open button wouldn't work. The charger is for 6v/12v and so it must have thought that all was well when it hit over 6v and battery wouldn't take anymore. Struts should be getting reassembled with Konis this week, and I was even able to find Koni decals with the right shade of blue to put on struts! Anyway, latest pics . . . (yes, I know it's silly to paint the tiny OEM front calipers but it'll have to do until I can save up $$ for upgrade)20170831 185508 20170831 185514 20170831 185527 20170831 185534
gamefanatic
Barstow, CA
Nice! Do you have pictures of the intake / valve covers? About how much did it cost you to get those done?
