20x10 20offset. All the way
Corey Sig
2011 SHO PP
MD
Will 20x10 with 20 offset fit all the way around my 2011 SHO pp with H&R springs? Would also like to fit 275x45x20 all the way around. What do you guys think, Will it work?
Corey Sig
2011 SHO PP
MD
These are the wheels.
20x9.5 fits with +36/+42, so 20x10 should fit with +20, I would think. One SHO owner has done this with 20x10s and Megans, IIRC, Jacob (2015 SHO?). Also Zach, 2015 SHO with 20x10.5 (probably a bit extreme LOL).
http://www.ecoboostperformanceforum.com/index.php?action=dlattach;topic=747.0;attach=10915;image
20x10.5 +25 offset
http://www.ecoboostperformanceforum.com/index.php?action=dlattach;topic=4943.0;attach=9821;image
http://www.ecoboostperformanceforum.com/index.php?action=dlattach;topic=4943.0;attach=9823;image
More here
http://www.ecoboostperformanceforum.com/index.php/topic,5860.0.html
Corey Sig
2011 SHO PP
MD
Yes it's on H&R springs. I was thinking about doing the 9.5 also. I knew those would fit. The front is my main concern.
JasonoftheRugar
Wisconsin
I am using the H&R springs first off. The 20 x 9.5-30 fits fine up front with no issues, however I'm fighting the rear-same size. It's rubbing on the inner plastic fender well on the left and right side of the tire-not the top. I tried to correct with a camber adjustment, but didn't like the look of the angle. Currently I am grinding some of the plastic away and I put the camber back. I can see why SHOdded's offsets work because the wheels don't stick out as far. A 20mm offset would be pushing it. Mine stick out past the front fender about 1/4". A 10" wheel with a 20mm offset would put it out another 1/2". That would be no bueno.
Corey Sig
2011 SHO PP
MD
Hmm. Doesn't sound fun. What tire size you have on it? So on the rears it wouldn't work. Would have to go with a bigger offset or shorter width?
JasonoftheRugar
Wisconsin
275/40/20. Rubbing on some plastic is no big deal. That can be fixed. Rubbing on a shock or some other piece of frame work would really be a challenge. i lucked out. I'm not saying at all a 20 x 10 or 9.5 with a 20mm offset would not fit. Just letting you know what I'm dealing with. After the snow melts once again, I'm taking it out to see if I fixed it. Try to stay as close as you can to the stock 38mm offset.
Corey Sig
2011 SHO PP
MD
Hey Jason did you ever find out a solution to your wheels rubbing? I put mine on today and the fronts are rubbing on something. Tomorrow when I have an extra hand I'll be able to find out. I have access to a lift so I'll be able to have the car in the air while someone drives it. I'll have an answer tomorrow but just seeing what you ran into.
Corey Sig
2011 SHO PP
MD
Just an update... Tires were rubbing on the front... They were rubbing against the strut.. Advance is bring a 5/16th and 1/4 spacer. Going to see which one is gonna work for me or not.
JasonoftheRugar
Wisconsin
It was rubbing on the inner fender in these 2 places on the rear. Used a die grinder and a carbide bit to knock the plastic corners down. Filled the void that was created with epoxy.
Upload 2017 3 25 9 15 26
Corey Sig
2011 SHO PP
MD
I don't think mine was rubbing there I'll have to check again. Sucks the front is rubbing but I think a 1/4in or 1/8in should fix it.
93hostang
22x9 f 22x10 rear 245/25/22f 295/35/22 rF14f64b4b330a3f5c60c86caa3df41d17202d4e7f54fbae0f0a7088ca273326d
Sent from my XT1650 using Tapatalk
USMCsho01, where in MA. are you located? I'm in SPFLD, and would love to see that beast in person. Also, would like to pick your brain about wheel and tire sizes.
Looks damn good sir!
-Q-
