Victorious_Secret
How much water meth are your setups using on average? I have the Devils Own Stage two set up to begin spraying 15% at 6 psi and 100% close to 9PSi. I run through about two quarts a day even under normal non aggressive driving.
There are no leaks and I have seen some good power gains, thanks to Torrie for tuning. Its just the sheer consumption methanol I am worried about. I'm popping the hood everyday to refill and spending 45 bucks on 5 gallons of VP 100% meth more often than I would like.
One thing I did notice is that the system is spraying much sooner than when the W/M system dial is set to. Using my handheld SCT it seems the system begins spraying as soon as 2-3 PSI which would obviously lead to a lot of W/M us since I'm in that range almost always. how accurate is the SCT handheld? I think it would be really close since its getting data from cars computer.
Talked to Devils Own, they confirmed the numbers on the dial are start and full spray PSI numbers and suggested a manual boost gauge to verify and adjust.
Any ideas and what are your thoughts? Thanks again.
