I disagree with one part of your statement above - I do not think that you have ruled out the fuel pump check valve.
As I understand your results, if you cycle the key on/off several times, the fuel pump builds pressure and it stays up (at least for a while). But overnight, there is a good possibility that the fuel pressure has dropped significantly. If I understand that correctly, then in my experience it IS the fuel pump check valve that is at least part of the culprit for your loss of pressure.
