Need a MTX seal
RJ-92
Crappy NYS
Need a seal for the linkage on the MTX, rod shifter, where the shaft goes into the trans housing. Mine is leaking and has been forever. I might as well drain it and replace. Any ideas where I can score one?
RJ-92
Crappy NYS
You guys rule!!
Any experience replacing one of these?
What's the procedure? Does it go on dry or loobed?
Irish Pride
Irish Inside
MusicCityUSA
You always want to **** the inner part of any seal. For this case I would just dip my finger in some ATF and run it around the inside. Use a socket the same size as the seal to knock it into place or take the seal to a hardware store and get a section of pvc pipe the same diameter. Either way will work.
RJ-92
Crappy NYS
Thanks. That's what I thought, but wasn't sure. The main seal on my LS1 specifically said to put on dry.
The seal was new when the trans was rebuilt. It always leaked. Must have been damaged during installation.
FastCAD
Miami, Florida
Summit Racing has Timken seals for the Gen1 tranny.
AREA 91
Area 91
Make sure there are no burrs or rust on the shaft before installing the new seal.
