Kenneth Bridgman
- Joined
- Sep 10, 2016
- Messages
- 5
- Reaction score
- 3
What service interval are you guys using for your sho? Are you still using factory fluid or is there something better out there? I have a 2013 sho performance pack.
Why so often?I have been changing out my fluid about every 1k miles with standard conventional gear oil. I didn't see any reason to buy the more expensive synthetic fluid when I was going to change it out so often. Once the season is over I'll do a few changes with synthetic and change that out every winter.
I purchased the car at 70k miles. There was oil coming out the PTU vent and that told me it had become clogged with some sludge. I'm hoping that frequent changes will dilute the sludge. But I've only put 4k miles on the car all summer (1500 came from a week vacation to the UP) so it hasn't been changed to often. Plus it's about a 15 minute change after doing it the first time.Why so often?
Sent from my DROID RAZR HD using Tapatalk
Got yaI purchased the car at 70k miles. There was oil coming out the PTU vent and that told me it had become clogged with some sludge. I'm hoping that frequent changes will dilute the sludge. But I've only put 4k miles on the car all summer (1500 came from a week vacation to the UP) so it hasn't been changed to often. Plus it's about a 15 minute change after doing it the first time.
The problem with additives that will clean up gunk (ie, break down the oil) is that you have no good way to get all the oil out without removing the PTU. If cleaner gets left in the PTU, it's going to break down the good oil if you don't get every last bit of the cleaner out. I wanted to go that route but ultimately settled for many frequent changes and I tried to change them soon after parking. My thought was that any gunk remaining would mix with the good new oil and become suspended in it. Then when I suck it out, I can get more gunk out. After many changes, it will be diluted enough that it's basically all new oil.Are there an gear lubes with additives that could help clean up any gunk that's in there making the frequent fluid swaps more effective?
