bpd1151
Lurking Around
A tune only, from either vendor, will still pass emissions.
They are both excellent. With unleashed you aren't forced into buying certain items for tunes. Such as I don't have to have catback exhaust to run methanol. Where as with LMS they would require it. That's why I went with unleashed but once again both are fantastic
What he's saying is that if you choose LMS tune, you are forced (in certain mods) to use LMS mods. For example, LMS will NOT tune a snow performance meth kit. LMS will only tune for their meth kit. As long as you're buying all your stuff from LMS, you're good.Maybe I'm missing something here. I'm running LMS tune, DP, and methanol (straight M1) all installed by Livernios with stock cat back.
+1, I passed emissions in Georgia with my whole package installed. But not sure on different state emissions testing, Georgia's test was only 2 things: gas cap and ODB plugin to verify no check engine lights. I don't think their (emissions testing facility) had the sophistication to know what was a "stock" vs "custom" tune. Their machines basically just make sure you aren't driving with 10 (or just 1) check engine codes. Which in my opinion, is just another reason the states or counties are ripping of citizens. Oh well, probably for another discussion.![]()
I think what he's saying in his state they actually plug into the computer to make sure the computer is ready. When you disconnect your battery and reconnect it there are several miles one must drive before the computer gets everything "checked out" and it's ready. What he's saying is apparently on his tune LMS has disabled this so it will always read not ready. Normally I've seen this happen for keeping the rear O2's from throwing a CEL.A tune only, from either vendor, will still pass emissions.
I don't have testing so I haven't looked into it. The only thing I have is what the poster stated...."the last dialog I had with LMS was that they never turn on the "readiness" indicator"Regardless, a true "tune only" from either primary vendor, accompanied by no other mods, will pass emissions.
IIRC, the procedure you defined, it takes between 100-250miles driven, in order for everything to "reset".
If a state is just looking for codes they won't find any. But if it's a state where they plug into the car and actually read the status of everything, it will say not ready and they'll fail it until you bring the car back and it's status is ready. The reason is because some people will disconnect the battery to clear the CEL, bring it in for testing, and try to get it to pass before the car runs through everything and brings the CEL back on.
