Greg Corcoran
Just bought another Gen 2 after a 11 years a no SHO here... The car is low miles (77K) '95 MTX overall good shape and garaged, no mods that I can see so far, but has a pronounced stumble when cold from about 3000 - 3500 rpm. Goes away within minutes of startup. (Also needs a CCRM because the low speed cooling fan won't ever come on, but when I jump pins 3 & 4 to 1 &2 the fan comes on. When I ground pin 14, nothing. Former owner knew, and already had another CCRM stashed in the trunk, but he got a "J" and I need a "D" code apparently. NAPA says they can get one by the weekend for ~$125 so I ordered it.)
So- I decided to start troubleshooting stumble by pulling codes.
The method I used on my '92 to pull stored codes all those years ago doesn't genereate a MIL/check engine light at all. I have a short jumper I place between the gray connector and the top right connector on the black EEC IV plug when holding the black plug with the 2 conncection positions "up", 3 positions down.
I also just noticed the check engine light does not come on briefly when I start the car, or if I intentionally stall the car. I thought it did come on as part of the start sequence on my old SHO, or if the car stalled...
Any insight? And if MIL is disabled or burnt out, how hard is it to repair? I apparentkly gave away or sold my Helms manual for the '92, so I can't look it up.
Greg Corcoran
Longmont, CO
(Former member of CSHOC)
Greg Corcoran
Longmont, CO
