Customer Taurus Tuesday
Livernois Motorsports
SHOForumSponsor
Dearborn Heights, MI
Ian's 2014 Ford Taurus SHO
Rare Darkside Metallic paint, Tune by Livernois and CAI. Next up is down pipes, turbo upgrade, cat back exhaust and meth injection.
Ian is a true car guy as well! Not only does he have a SHO, but he also owns 2 of the most coveted vehicles ever...
2001 Nissan Skyline GTR R34
2003 Honda S2000
Butcher
Can you put upgraded turbos and a meth kit on a stock engine SHO? I thought one or the other was possible, but not both. How far can you push the stock long block before "weak spots" start showing up?
Butcher
Ok, but do you have customers that do it anyway? If so, what gives up usually? Is it something "minor", like the head gaskets? Or is it something "major", like the rotating assembly?
SHOForumSponsor
We do not usually have clients that disregard that safety warning. If someone did decide to do meth and turbos without the engine fortification we would have to water down the tune so badly that you wouldn't even know that there were aftermarket turbos on the car.
Butcher
Ok, then I would think the customer in this thread is getting at least a short block too. That will be a fast car, when it's all done.
What is the weak part in the short block? Rods? Pistons? Fasteners? Oil pump gears, just like the Mustangs?
mval
MISSOURI
angela: i am not a sleeper guy so wild ok but those ricers are too much. last week at at a local cars & coffee & one of these were there. i know a great car & expensive but i'd take the $$ rather than the car GT3RS. just got to believe the german engineers where visiting japan & had too much sake when they did this. 4 16cofcar6 zpsqkbrz7v7
SHOForumSponsor
They are all the weak points. The block itself being open deck suffers from cylinder contortion.
Rotating assembly is not made for that type of power nor RPM.
The fasteners do not the required tensile strength for that power level.
The pump gears are powdered metal...do I need to get into that one?
Still waiting for drive train upgrades. In the meantime, the tune can help the stock engine make same power with less effort after the turbos and meth kit are installed. Also means less stress on the engine. Wouldn't hesitate to do both now and short block later if you have to stage it.
