New SHO
2011TAURUSSEL
2014 SHO LMS Stage 1 V10
DFW Metroplex, USA
I would be curious to see what sequence number 140 and 142 are....even more so wonder if 140 141 and 142 went to the same dealer or same dealers in the area.
2011TAURUSSEL
DFW Metroplex, USA
The only variable numbers to check are the 7th 8th and 9th digit We can eliminate the 1LN (Lincoln since they apparently went out of production for 2016)
7 Is model series SE/SEL/LIMITED/SHO/POLICE. SE is one choice FWD SEL/Limited and Police is FWD/AWD SHO is one choice AWD
8th Engine code 4 choices 8 3.5 9 2.0 E/B T 3.5 E/B (SHO) or K...3.7 Police
9 Check digit 0-9
10 is model year G A-2010 C-2012 E-2014 - G-2016
11 is plant G Chicago
NOT SE
2011TAURUSSEL
DFW Metroplex, USA
Using 100140 as a reference.....
SE NO
SEL FWD NO.......I tried 3.5 and 2.0 for engine choice and nothing on either one either model.
BlueSHO
Ok interesting
Sent from my DROID RAZR HD using Tapatalk
BlueSHO
My vin is 1FAHP2KT0GG100141
2011TAURUSSEL
DFW Metroplex, USA
Check digit is a single digit computer generated number also could be X....
I found 140...took a while but I found it.
100140 Limited AWD Appears to be 301A Package Moon roof/NAV 20" Cast Aluminum wheels.....split spoke California Emissions.
Guard Exterior/Charcoal Interior. Doesn't say what dealer it went to but since California emissions we could probably conclude not Texas or Ohio or any other non California Emissions state. Axle ration 3.39 interesting mine is AWD and only has 2.77 I wonder if they changed rations for 2016 AWD models?
BTW Start with AWD First reduces one engine choice since the 2.0 is not available with AWD.
Pintony
40 miles N.E. of St; Louis
Nice JOB 2011Taurussel!!!
2011TAURUSSEL
DFW Metroplex, USA
The P2KT0 for blue is correct it could be 0-9 or X Everything up to P2KT is ALL SHO T engine everything after that is variable.
I will try 100142 some other time.
2011TAURUSSEL
DFW Metroplex, USA
I started a cult....Tony it doesn't count unless you get model, option package, stand alone options, paint and interior color......the city is bonus where did you find that?
Pintony
Missing
* Illustration shows model only
Taurus, 3.5L DOHC V6 Petrol T/C, Blue Jeans Metallic
VIN Number: 1FAHP2KT4GG100708
Registration information for your currently selected Vehicle:
First Registration Date:
Registration Number: Registration Date: Registration Country: Modified Date:
Historic Registration Dates:
Primary Features
Build Date: 19.12.2015
Vehicle Line: Taurus
Body Style: 4 Door Saloon
Version: SHO
Engine: 3.5L DOHC V6 Petrol T/C
Transmission: 6 Speed Auto Transmission 6F55
Drive: LHD 4WD (FTD)
Axle Ratio: 2.77
Emission: With 49 State/Non Green State Req
Air Conditioning: Dual Zone Auto Temp Control A/C
Territory: (+)"USA"
Paint: Blue Jeans Metallic
NavPanelArrowCloseDown 18x18
Minor Features
  • Charcoal Black Interior
  • With Wrapped "B" Pillar Trim
  • Rear End Fascia - Level 2
  • Fr Dr Scuff Plate - Met Insert
  • Less Body Armour
  • Less Cargo Stowage Device
  • With Front Fascia-Level 3
  • With Performance Front Fenders
  • Driver & Passenger Seat Map Pockets
  • With Heated/Cooled Front Seats Only
  • Less Centre Console Top Finisher
  • My Key
  • (-) Version Packages
  • Chicago Plant Build
  • Less Appearance Group
  • Less Trim Pack
  • With Memory Pack
  • Feature Content Group 1
  • Less Paint Package
  • With English Language Label
  • Owner Hand Book Pack
  • Less Mass Customization Package
  • "A" Pillar Cloth Trim
  • "C" Pillar Cloth Trim
  • Power Front Wndow-1 Tch Up/Dwn-Pass
  • With Electric Rear Windows
  • With Solar Tinted Glass
  • With Front Side Laminated Glass
  • With Aluminium Instrument Panel
  • Standard Ovrhed Console & With Rail
  • With Full Floor Console
  • Less Rear Floor Console
  • Memory Adjustable Foot Pedals
  • Front Throw In Mats With Logo No.2
  • Rear Floor Carpet Mats
  • With Carpet Floor Covering
  • With Illuminated Sunvisor - Drivers
  • With Illuminated Sunvisor-Passenger
  • Door Trim Panel Insert-Film 2
  • Grab Handle Side Door - Plastic
  • With Power Rear Sunblind
  • Trim Rear - High Line
  • With Load Retention Net
  • Spare Wheel Stowage Cover
  • Grille - A-Gloss
  • Less Active Grilleshutter
  • Bright Greenhouse DLO Moulding
  • Less Door Edge Guards
  • With Single Rear Wing Spoiler
  • Inside Mirror With Auto Wipe Sensor
  • 4 Door Saloon
  • Dual Pwr/Htd/Fld/E'Chro/Pudd Lamp
  • Ext Mirror Finish-A Gloss Skull Cap
  • Less Rear Sliding Seat
  • With Rear Center Head Restraint
  • With Heated Rear Seats
  • 2nd Row Seat 60/40 (3 P) - Folding
  • Less 3rd Row Rear Seat
  • With Driver 8 Way Pwr.Seat Adjuster
  • With Pass 8 Way Power Seat Adjuster
  • With Programmable Driver Seat
  • Less Interceptor Siren/Speaker
  • Less Special Service Vehicles 1
  • Less Special Service Vehicles 2
  • Less Special Service Vehicles 3
  • Less Special Service Vehicles 4
  • Less Engine Oil Cooler
  • Body Coloured Exterior Door Handle
  • With Leather Gear Shift ****
  • Less Decklid Pulldown
  • I/P Mount Deck Release-Battery Pwrd
  • Less Keyed Alike Options
  • Frequency - 315MHZ
  • With Central Locking System
  • Keyless Entry/Start - Passive
  • Rain Sensitive Windshield Wipers
  • With Tilt & Slide Sunroof
  • Less Tu-Tone Accent Colour
  • Less Front License Plate Bracket
  • Side Air Bag - 1st & 2nd row
  • Rear Seat Belts-2nd Row
  • Spare Wheel-18" Mini
  • 20 X 8" Machined Wheel
  • P245/45R20 V Rated
  • 18" Mini Spare Tyre
  • Less Wheel Covers
  • Less Immersion Heater
  • With Remote Starter
  • With 49 State/Non Green State Req
  • With Standard Suspension
  • 2.77
  • 3.5L DOHC V6 Petrol T/C
  • Dual Exhaust
  • With Dual Chrome Exhaust Extension
  • Power 4-Wheel Disc Vacuum Boost
  • With Painted Brake Calipers
  • With Anti Lock Brakes And ESP+
  • Normal Fuel Fill
  • Less Transmission Oil Cooler
  • Floor Shift
  • Select Shift Tech (SST) W/Pad Shift
  • Non Locking Capless Fuel Fill
  • For Unleaded Fuel
  • Unique Met Finish Foot Pedals Pads
  • With Electric Power Steering
  • Power Tilt/Telescopic Strg Column
  • Less Steering Column Lock
  • Sport/Leather Steering Wheel
  • With Heated Steering Wheel
  • Less Electronic Speed Limitation
  • With Speed Control
  • Redundant Controls-Steering Wheel 2
  • With MPH/KMH Speedometer
  • Less Tyre Inflation Kit
  • With Header Mnt Compass/Thermometer
  • With Nav System-Becker Traffic Pro
  • Less Lane Departure Warning System
  • With Blind Spot Monitoring
  • Human Machine Interface 4
  • With Perimeter Anti-Theft
  • With Rear Parking Aid
  • Less Front Parking Aid
  • Less Automated Parking System
  • Medium Duty Battery
  • Heavy Duty Alternator
  • With Region 1 Electronic Equipment
  • AM/FM CD/Clock
  • With Satellite Radio Reception
  • With NAAO Radio Frequency
  • HD Radio Broadcast
  • With Level 2 Sound System
  • Less Radio Suppression
  • Sync III
  • With Universal Garage Door Opener
  • Less Wiring Prep
  • Less Smokers Package
  • Rear View Camera-Fixed
  • Less Fog Lamp Bezel
  • With Auxillary Lights
  • High Intensity Discharge Headlamp
  • Less Daytime Running Lamps
  • Less Front Fog Lamps
  • Less Spot Light
  • Less Right Hand Spot Light
  • With Ambient Lighting-Interior
  • (-) Package Ty/Dk Lid Lamp-Pre Wire
  • Tail lamps - Level 1
  • With Auto High Lamp Headlamp
  • Less Wiring Harness
  • Less Power Distribution Box - Front
  • Less Accessory - Packages
  • Blue Jeans Metallic
  • Generic Country Group 1
  • 6 Speed Auto Transmission 6F55
  • Taurus
  • SHO
