Stock Drivetrain Limits
Cruxin
Greater Milwaukee Area
Every car is only as good as it's weakest link. I've been trying to do some research on what fails first on the 2013+ PP SHO's once the bolt on list gets long, but I have not had much success. Common knowledge for Subaru guys is once you get over 300hp at the wheels on an EJ257 STi you are in danger of your piston ring lands failing. Are there common WHP #'s like this for the SHO platform? I've listed out some components below if you guys could fill in the blanks on what power level they fail.
Engine:
Pistons:
Rods:
Bearings:
Headgaskets:
Transmission:
PTU:
Driveshaft:
Axles:
Diffs:
Also has anyone done any 1/2 mile events and survived? Unlike this Mustang's driveshaft :evilgrin:
BamSHO
South Williamsport,PA, US
We actually don't know the true limits yet. We do know the fluid need regularly changed out in the PTU. As for HP related failures, that is the million dollar question. I did a full season of drag racing with my tuned '12. No driveline or motor failures.
as I understand it, the racing guys are running over 600 hp on stock internals, with the right tune, injectors, etc.
The GT now makes the 600+ hp figure with a PFI/DFI setup on the 3.5L EB in 2016. Crank hp, mind you. Plenty of Gen IV SHOs around already putting out well north of 500+ crank hp as DDs with stock internals (though supplemented with meth).
Jedster1
2015 SHO PP
Hixville MA
What? Blow them up? Regularly? :eeeeeek:
Or run crazy horsepower through them and they hold together?
shoblock
Cleveland and Naples
PP's have different pistons and rings than non-PP. The reason is that these are police interceptor motors, designed to idle for a half hour then go to wide open throttle indefinitely. Ceramic is one of the premium materials. Can't divulge any more.
If you have a pp, you will have different limits than a non PP. Also, since earlier this year, all blocks now have fine thread main bearing caps, much stronger, though it will only apply to Flex, F150 and Explorer sport. Still something to consider during a rebuild.
Livernois Motorsports
SHOForumSponsor
Dearborn Heights, MI
The new GT is a completely different animal. Different in every way all the way down to its fuel systemS.
Vortech347
Where did you reference this?
Cruxin
For EcoBoosts only use MS109.
What have you found to be the limit of the Trans/PTU?
Very helpful! One more tick in the "Pro column" for purchasing a PP.
shoblock
Actually, many of the failures come from components you wouldn't expect. Today, we heard about a loose turbo drainback causing the loss of 4 quarts of oil. Coolant hose connections will drip under pressure while underway, then stop when you shut the engine off. Leaks occur around sensors, and cam covers. Most are very small leaks, undetected or ignored, that add up to an unacceptable amount of fluid loss.
Walk around your car, and look at the ground after you back out, at least once a week. Many ecoboost motors could have been saved by a simple owner observation!
