2014 SHO Rain Sensor Cover Removal
Badfly48
I recently purchased a new 2014 Ford Taurus SHO (I'm thinking about making a separate post on here with pictures of it) and I was hoping to be able to tap into the power of the auto-dimming rearview mirror to power my radar detector. However, the connections are located behind the cover that I assume houses the rain sensor. I have no idea how to remove it. Any ideas, or advice from someone that has done it on their Taurus or other late model Ford would be greatly appreciated!
Bosscav
PA
Do you have a moon roof? That's what I would suggest you tap off of. If not, then the map lights and just turn the radar on when you need it and off when you get out of the car.
That rain sensor array is very delicate part. I wouldn't go anywhere near it
Badfly48
How would you recommend going about tapping into the moon roof?
Bosscav
PA
The sunglasses holder pops right out if you use your fingers on either side. Super easy, no clips or anything. Tap those wires and run your wire out the front.
Badfly48
Sorry I'm not sure I follow you... I take out the sunglass holder and then what?
Bosscav
PA
Take out the whole sunglass holder / map light / moonroof switch unit and you'll see plenty of wires to tap to ;) just tap into the moon roof wires and the detector will turn on when the vehicle turns on and off when it's off. Definitely ideal.
If you need a better explanation, PM me and I could give you a call if you prefer.
Badfly48
I know how to tap into the wires and route it through and everything. I just don't know how to remove the map light/sunglass holder assembly.
Bosscav
PA
I'll snap some pictures tomorrow. You have a 2014 right? Should be the same as my 2010
Bosscav
PA
Give that ^^^ a shot. I havent uploaded a video to YouTube in a long time so Im not sure how to share it.
shoblock
Cleveland and Naples
Thanks, but that seems way too easy! I'm always afraid to force interior parts, unless I know they snap out like that.
Appreciate your time and effort, my Valentine 1 detector thanks you also, Bosscav.
