Project '95 Restoration
eacyde
Pinkley Taurus
Calgary, Alberta, Canada
Made some more progress.
Installed the steering column, gauge cluster (with 40K less KM:angelnot:) and EATC.
So far, so good. The car started up with no issues.
Still trying to figure out the random plug. Maybe its nothing.
eacyde
Pinkley Taurus
Is there a way to straighten the bars on the vents? For some reason, the buckets and the vents were warped. I used the buckets from my Mocha trim piece and installed the black vents into it. These are the middle vents if it matters.
See pictures of warpage
eacyde
Pinkley Taurus
I have spent a few hours here and there buttoning up the car. I had a small issue where the automatic headlights were not working. I had a mystery connector behind the auto dim module that didn't have a home. I didn't feel like climbing under the dash so I called it a day. The next day I poked around the harness and found the other end, plugged it in and the auto headlights worked.
I ran into a small issue with the upper B Pillar trim. The Black interior came from a 93, my car is a 95. Who knew the upper seat belt location is different? I had to paint my mocha units.
I also had to paint my Mocha lower section of the center console. the previous owner of the black interior hacked in some speakers.
Before pic of console (After in a few days. I ran out of paint)
eacyde
Pinkley Taurus
I started to paint my grey upper ATX console and the paint is bubbling is some places.
It seems that the grey interior pieces have a rubber coating.
I think I may have to sand it down to fix the issue.
eacyde
Pinkley Taurus
Would sand blasting be to aggressive? Maybe a little bit less time consuming.
I thought about that but my blast cabinet is too strong.
I scraped the offending area, then sanded, then cleaned, the dusted the paint on, so far it seems to be working.
Lower Console Painted Black
Upper ATX Console so far
kevinspann
Don't take my advice.
Richmond VA
All of the console tops have a rubber coating. I've stripped it off using brake fluid before...
NCSHOracer
Fear The Rasp!
North Carolina
I took a mixture of pine sol and old english in a warm water tank to strip the coating, it didn't strip it as much as soften it enough to be removed by a toothbrush. But the end result turned out good for painting.
eacyde
Pinkley Taurus
Spent some quality time with my fog lights today. Any tips on removing the lenses to restore the inside?
What I am working with
After 220 grit
After 800 grit on the Left
After 1000 grit on the Left
After 2000 grit on the Left
After 3000 grit on the Left
Polished up
DONE
shobroooo
