Slight knock from front left wheel
Jilogethan
Iowa
I am hearing a slight knock from the front left area.
It happens sometimes on bumps, not all the time. Dont really notice any other odd behavior. I had a Grand Am back in the day that had a similar noise and it ended up being a broken sway bar bushing. Ive read on a forum about somebody replacing a tie rod end on the SHO.
Also, the intermittent wipers are kind of screwed up, none of the settings seem to be consistent, on the least frequent setting its like a 20 second delay then sometimes randomly goes full on for 3-4 swipes then off. On the most frequent setting I get a swipe, 3 second delay, then a 8 second delay. Very odd indeed.
I really love the car, especially the AWD, I live in Eastern Iowa and travel all over the midwest. Ive just installed a K & N drop in, got SEL tailights going in as soon as we get some nice days then a windown tint.
FoCoSHO
Colorado
Not sure about the knock, but as far as the wipers go, mine does the same thing when I have the rain sensing turned on........works as designed. If you turn the rain sensing off, the intermittent wipers are consistent.
MNRubyRed2013
If I remember correctly the rain sensing wipers cannot be turned off on 2010-2012, like on the 2013+.
esfoad
Esfoad
New Jersey
That is true, it cannot be turned off. What looks like intermittent settings is actually adjusting the sensitivity of the rain sensing system.
Zylfrax791
Lake Oswego, Oregon
Yes. Whenever I slowly go over a speed bump I hear/feel this sort of clunking sound from the left front wheel area. As soon as the ice/snow is gone and we get a dry day I'm going to jack it up and scope it out or when I have the oil changed I'll ask them to take a look at it.
TimboSHO
Intermediate
Wyoming, MI
Knocking sound is likely a stabilizer link. If you can jack it up and get the wheel off, you should feel play in one of the 2 ball sockets. Before taking the wheel off, be sure to check for play at 9 and 3 (tie rod end) and also 12 and 6 (ball joint).
Jilogethan
Iowa
Thanks for the advice but I havent a clue on the 9 and 3/12 and 6. Will take the wheel off and do some spot checking, just dont want to run into any big issues.
He was referring to the clock positions, so basically, check for vertical play on the wheel while you hold the top & bottom (12 & 6), and then horizontal play while you hold it from the left and right (9 & 3) positions. How much can you get the wheel to move in each of these positions?
Jilogethan
Iowa
Thank you SHOdded, will try once I get her home
