The one on the passenger side by the grounding strap.
UPDATE
I went out and started the car today, as I try to run it for a half hour or so and drive it around the block every couple weeks just to keep the fluids running. The idle has started to become slightly erratic. The important thing is that while I was looking over the engine while it was running, I heard something I had not noticed before: a fairly loud clicking noise coming directly from the coil pack. I did a little bit of general research on coil packs, and supposedly a loud electrical clicking noise means something internal to the coil pack has cracked and is causing an electrical short, which may be causing all my problems. I'll see if I can scrounge up some coin to get a new coil pack soon and see if that fixes it.
Anyone know what other cars use the SHO's coil pack type? If it's fairly common I might be able to snag one at the junk yard.
