vortex2450
Buying Parts...
So I've been contemplating fabbing up big bore intake horns to replace the stock horns since I believe that the engineers knew what they were doing as far as intake tuning goes and that removing the horns to install BBB's is less than ideal. I've been drawing up a plan to have a set made for myself but since it could be potentially cheaper if I made a batch I was curious as to who would be interested?
I don't have any solid figures yet but it looks like it will cost about $80 to make just one set w/ materials. I plan on making new flanges from 10-12 gauge 6061 al and the horns will be ~40.23mm ID 6061 tubing. I will weld them myself with a industrial quality TIG welder so I while I'm no pro I am half decent with it. They will be flared just like the stocker and I will have them bent as close to spec as possible.
I plan on eliminating the stock in/out fitment for an outside groove weld and then porting the inside joint together for best airflow.
Well, I just wanted to throw that out. I don't want any money now but if it seems a few people want a set I will go ahead and plan on making multiple runs.
Thoughts?
-Josh
Thoughts?
-Josh
