platoribs
Live to Drive
Anybody seen or done this? what do they do? Oval out along the radius 0.25"
wonder how badly it effects the structural integrity?
got your avatar on my rear glass, thanks.Josh
Do you have any pics of that Sam? My SSRs were custom ordered as 5x108
Actually I'm looking into having the 13" mustang rotor (RA $60/per) modified to fit on a 5x108 pattern for Cobra calipers... on a Thunderbird SC, or an SHO...:sun:
Key is to find a place experienced in this that also knows to press in steel lug seats (which will occupy the "space" left over if you simply whittled away the aluminum to make it "fit".
This is exactly right. The inserts are supposed to only be good from 3-8mm. -Sam
One option is to source 5x4.5 hubs and bearings to to match the OEM ID of the knuckle (if using gen 1/2 knuckle) and OD of the hub sleeve.
the rear mustang hubs, and front taurus hubs (gen 1 and 2) use the same wheel bearing. a timken set49.
there are some aftermarket replacement hubs that are same thickness around the entire stud surface. Would be easier to redrill to new bolt pattern in the empty middle space.
