No Fog Lights
javve
SHO Lovin' It
Eastern Washington
When I traded my 93 for a 95, I got it with busted fog light lenses and bulbs. I got different lenses and new bulbs, went to check em out, and notta. The light on the fog light switch turns on.
Where is a good place on these cars to start tracing? I really do not want to go the route of wiring em directly to the switch. I tried searching the forums but the search wants to time out on me.
Keeping myself occupied while waiting for the fuel related parts :angelnot:
Irish Pride
Irish Inside
MusicCityUSA
the fog light fuse is mounted under the dash but not in the fuse box. it is a seperate fuse all by itself. remove the panel under the steering column and you should find it pretty easy. see if that fuse is bad first.
StreetlightSHO
It'll run eventually...
Phoenix-ish AZ
Piggybacking on this thread a bit.... Same problem.... I had do rewire my fogs because they were all chopped up, but don't have any voltage at the fogs. I pretty much know it's the fuse, but I cannot find it under the dash for the life of me. Can anyone find a pic of what and where I should be looking?
javve
SHO Lovin' It
Eastern Washington
Says under the dash near the fuse panel attached to the main wire harness. Looks like directly under the headlight switch or near the ebrake pedal from the diagram.
The Ford wire diagrams show a 15A in line fuse for the fog lamps.
I don't have any experience with this problem, but I do have a service manual for a gen2.
I can't tell where it is by looking at the service manual, it looks like it may be part of the switch, or else near it.
Here's the diagram. Hope it helps.
2889493500 eea7512f4d o
That is what I found with a search. I am off to go see if I can find it then once I do, will have camera ready.
javve
SHO Lovin' It
Eastern Washington
Found it!
With the bottom cover off, it's just above and to the left of the fuse block. I think it is supposed to attach to the frame of the dash. Mine was hidden away but I took a picture of it back in where I think it was supposed to be. My fog lights work now. Fuse was indeed blown.
FogFuse1
FogFuse2
FogFuse3
StreetlightSHO
Phoenix-ish AZ
Trying out my fog lights for the first time ever!
:woo-hoo:
shobroooo
