Bull Geek
So my recent purchase, a 1997 Ford Taurus SHO w/the 3.4 V8 (Vin 'N')...from what the prior owner said, it runs hot and "may need a head gasket".
Reviewing the service records, I see...
4/22/2011:
*P0411-Diagnostic performed using Ford flowchart. Found air injection pumop works. Air is getting pumped. Unable to find any problem in system to explain why CEL illuminated. No test for air diverter. Cleared code/reset CEL.
*6.5 qts of High Mileage Shell 10W-N.
6/15/2011:
*Customer Concern: Car started running hot and pouring antifreeze. Immediately shut car down before got to H. Towed in.
Added water to cooling system to Test. Pressure tested system, finding leak coming from upper rad hose extension from connection to engine.
*Replaced Short upper rad hose from connector to engine (not to rad), added Antifreeze.
*Fixed high idle issue. Foam gasket stuck in throttle allowing unmetered air in.
7/22/2011:
*Customer Concern: car began running hot again. Shut car down, towed in. Leaks Antifreeze quickly. Customer states only leak coolant when car is moving (**note, to me this says car is under load, gas pedal is applied, I think this is a clue***).
Shop states:We replaced upper rad hose previous visit.
During inspection, found coolant reservoir leaking coolant. Recommend replacing it. Believe there may be a head gasket leak. Recommend running block test. After engine run a very short time, a lot of pressure in cooling system.
* PS pump leaking, no repair done(**already saw fix on net for this, no big deal**)
* Replaced coolant reservoir with F6DZ-8A080-B. Added coolant.
* Block test: Performed block test with confirmed hydro-carbons in cooling system. Far most likely cause is head gasket leak. Compression from cylinders bleeding over into the cooling system resulting in far too much pressure than cooling system is designed to handle causing repeated items leaking. (***Is this plausible???***?) Recommend replacing head gasket.
So right now I'm puzzled what to do.
Do I:
A.) Go ahead, dismantle the upper part of the engine to check if a cam weld is needed, and if so, do the cam welding? Then do the cooling system repair/diagnosis.
B.) Try to diagnose the cause of the cooling system/"head gasket" issue first?
Option B means that if my cooling system work involves running the engine, I risk killing the engine if the cams are not welded.
Regardless...where do I even start with diagnosing this cooling system issue instead of throwing parts at it like Greenville Auto Repair did.
Thanks for any assistance and sorry for the long winded reply.
Nick
4/22/2011:
6/15/2011:
7/22/2011:
Do I:
Nick
