Jag wheels
Anonymous
Philadelphia,PA
I wanna put a set of jaguar S type R wheels on my 95 ATX ...the wheels are 18x8" front and 18x9.5" rear and they the same exact 5x108mm bolt pattern as the SHO , It's kinda hard to find some aftermarket racing wheels for these cars especially a set of staggered wheels with that bolt pattern so I wanna know if I can make that happen ???
LOUDSHO92
Rancho Cucamonga, CA
The widest rim you can fit is 8". So no.
With a front wheel drive car you would want the wider wheels up front.
SHONut has some nice Team Dynamic Rims.
93markVIII
MO
D7c5d962
these?
the +60 makes it a very difficult fit. even if you had the room, they would sit way deep in the wheel well.
17x9 TD PR1 275/40 23mm offset
IMG 0118 1
17x9 Front (23mm offset to fit 275 slicks) and 17x8 rear (40mm offset) Team Dynamics pro race 1.2
it would appear a 17x9 fits with a +23 offset. i wouldn't do it on a street car though. it isn't practical. they would throw rocks down the side of you car.
what's the width of the SHO slicers ?
the slicer is a 16x6 with a +42 offset.
SHOspazz92
Banned
Triad Area, North Carolina.
Where do you get your information from?
a 17x9 will fit with as little as a 32 mm Offset (and Barely stick out from the wheel wells) if you keep the tire size down to a 245 to 255. I run 17x9's up front with a 23mm offset, only so I can fit my 275 slicks up front.
For years many people have been running 18x8.5 wheels too, with the right offset.
-Sam
