Not sure on the drilled holes, I'm too lazy to pull out the diff I have.
However: That ring gear has been off of that diff. It's put together with bolts instead of rivets. Not sure if Doug had to do that or not. If not, that trans has been apart more than once for sure. I wonder if it was shimmed well or not, to shred third like that.
Edit: I pulled a diff out and looked, those are holes that he must have drilled.
So at least he did what he said.
The drilled holes will help with getting **** to the center of the diff where the whole issue begins. But in reality those little tabs welded on there have no leverage to hold the diff pins in if the roll pins were to break IMO it would do very little at that extreme angle.
The problem with the diff is not the roll pin. It is the way the spider gears rub the diff pin itself wearing it to the point of it welding itself. When the spiders spin and weld to the diff pin, it shears the roll pin and launching the diff pin through the case. IF he inspected the diff pins for wear, drilling the diff for more lubrication would be plenty to make it live.
OTOH. Welding to the diff pin is like trying to secure that wedge with bubble gum. Take a hammer and wack the weld at the pin. $1000 says it breaks off... Asked me how i know..
Wow, I feel mutch better about my reinforced diff's out there.
It held up to some good abuse it sounds like, so I would say it has done its job.![]()
My point exactly. About 60+ passes on the strip and not being affraid of the burnout box. About 15kmiles of DD, one wheels peels and mountain runs. I think its a pretty beefy stock diff. it did its job. im happy.
FWIW, I did this on my first MTX SHO with a completely stock diff and stock clutch. It held up just fine in the 60ish thousand miles I owned it too. Anything can happen.
95? Broken pressure plate, I drove it 30 miles like that. Front tires were bald, rear tires were 90%... Car was driven hard to say the least. Trans still shifted fine on the way home. That thing is sitting in my garage as the spare.
