Need emergency help
93.SHO.junkie
arizona
I just did timing on my 3.2 sho but now its all together..and somhow theres no spark like the engine turns over fine but theres no spark getting to the sparkpkugs at all ...any help here ...any ideas ...thanks
AREA 91
Area 91
Make sure the intake ground strap is connected on the back passenger side of the intake.
Check that the crossover tube is bolted down.
Mr Anonymous
Tire Wall
St. Louis, MO
i have a after market intake on it the only plug in is tha mas thats it
The intake manifold. That big aluminum thing on top with the snakes and such? Make sure the ground strap is attached and the two bolts holding the crossover tube (the DIS is bolted to it) are there and tightened as well.
Also make sure that the PCM ground is connected. It's the small wire that runs from the neg. batty. terminal. Follow it to the connector.
JRA2000TL
The Complainer
Daphne, AL
No no...he's talking about the intake manifold; the big silver thing that looks like a bundle of snakes on the top. On the passenger side of it; there's a crossover tube with the gray DIS module attached to it. That tube is clamped to the main intake manifold setup. The ground strap is on that rear corner (passenger side). It's a fla wire with a little ring on the end. All of that needs to be good and tight. Your 4 screws holding the DIS on need to be tight, but I don't see any reason why you would have removed that.
frosho
WOLFMAN
Tyngsboro, MA
Search the forum for "intake ground strap" and you'll find plenty of info, and even some helpful pictures.
93.SHO.junkie
arizona
ok so i checked all that and its all good theres still no spark what should i do is there anyone in az that can help... i need my car running but idk whats wrong with it...thanks
kevinspann
Don't take my advice.
Richmond VA
How did you check for spark?
Did you ground the spark plug that you pulled out to check it with?
zach44102
BIG TURBO
Georgia
Ok here is a list of things to check since the ground strap in connected to the back of the intake manifold.
1. Check the crossover tube bracket. Be sure all 3 bolts are in it.
2. Are all 4 bolts in the dis?
3. Check for 12v at the coil pack
4. Did you replace the cps when you reset the timing?
5. If so did you properly gap the cps?
6. Any codes?
7. Try taking some speaker wire and wrap it around the 2 bottom dis bolts and ground those wires at the neg battery terminal
I sure hopes this helps.
93.SHO.junkie
arizona
ok from that list all 3 bolts are conected i only got 3 of the 4 bolts on the dis
and how do you reset the cps sensor
and idk how to test the coil cause i honestly think thats bad cause i conneted a bracket to the alternator and wen i plugged the battary in it shorted so i took it off but whatever that did i think broke it
i checked all fuses and inside fuses and relay up front
idk if theres any more relays that might be blown idk where they are located so if anyone can help :thankyou::thankyou::thankyou:
93.SHO.junkie
arizona
ok so the dis is bad i tested it and its bad... so if anyone has a good one for sale let me know or where i could get one:thankyou:
zach44102
BIG TURBO
Georgia
You cant really test a DIS. I know you can at autozone but out of the 4 I tested there that where "bad" three of them worked fine.
If you have only 3 DIS bolts you need the two on the bottom. Thats the grounding path.
93.SHO.junkie
arizona
ok well i got all 4 bolts in and the way to test the dis is with a volt meter put it on the risistance one and touch ground to one side and power to other and it will come up with a number for each one then you go to auto zone and do the same thing with volt meter to the new one if the numbers dont match you know something is bad in the one you got thats how i found out...'
also found out my timing is major bad idk how to time it it has no timing cover what so ever lol so idk :thankyou::thankyou::thankyou:
