93rev2sev
If you timed it correctly when you put it back together, and then turned the engine over, the timing marks will have moved and they will never line back up. If you want to check your timing, pay no attention to the belt. Pay attention instead, to the dots on the sprockets. If the cam sprocket dots are both in the 12:00 position and the crank sprocket's dot is pointed at the bump on the oil pump housing, you're cam timing is good.
Did you gap the Crank Position sensor when you put it all back together?
