LongIslandSHO
Hi all...
Ok, so I had a problem with my A/C... the clutch gap was too large, so I re-shimmed it.. but obv had to pull the battery in order to do that.
Ever since doing this, the engine seems to miss/hesitate under load when cold, but then seems to be ok once it gets up to temp. Also seems to do it moreso in 1st, 2nd gear while accelerating than any other time.
Bad hesitation, and sounds like clanging or something... but it doesn't stall... tach doesn't drop out, etc.. No CEL.
I will see if there are any codes tomorrow, but I'm just curious if perhaps someone has an idea of what it could be, and point me in the right direction?
I did a full upper/front 60k about a 16 months ago (8k miles).
Besides disconnecting & reconnecting the battery, and re-shimming the a/c clutch, I didn't touch anything else - which is why I'm perplexed. Car ran absolutely perfect until this.
Any/all help is greatly appreciated!
Thanks!
Gregg
Thanks!
Gregg
