ok folks here we go..... Dont get mad ... jUST TOOK OUT MY BOSCH +4'S. THEY LOOK FINE.. NICE AND WHITE.. ALMOSTY NEW LOOKING.. pUT IN THE AUTOLITES.. THE WEBSITE SAID THEY WERE PRE-GApped . checked and all at .44 Now my car runs worse... What ********. Even the ad said that they were made for dis systems. Many people said Boschs were not good.. how can this be? Also i have bosch 8 mm wires and tthe autolites seat perfect on the plug wells so i have no idea how water can get in there. I must need a cam or tps sensor.. what else? no codes whatsoever?
Keep them for my next car and change my coil pack. Could that be the culprit?
just so i get this right motorcraft SP497 (finewire platinum) is the correct plug to get instead of the AGSP32PP or AGSP32FM (double platinums) ? it seems to be the only one that part stores have
Cuz I had a misfire and people said bosch +4's don't work well. The problem only happened after it warmed up. Someone thought maybe gps sensor. Will a code show up without a cel? I cleaned the maf
SP497 is the stock number for the 32FM plug, so yes. Once you take the plugs out, you'll see the FM number on them.
MOTORCRAFT Part # SP497 More Information About this Part {#AGSP32FMF6} Finewire Platinum
Category: Spark Plug
Part Image
$3.07
Add Part
