Locking Timing Chain Tensioner?
illSHOyou
Troy, MO
Whats the best way to compress the timing chain tensioner and lock it into position? I have the motor times at #1 TDC and pulling the front head off, but I need to release the timing chain and not damage the tensioner. Whats the best way to go about this?
Mr Anonymous
Tire Wall
St. Louis, MO
There's a small hole on the front to stick in a paperclip to keep it from extending.
To retract it you'll need a small slotted screwdriver to release the ratchet via the larger hole on the front while compressing the piston back with a set of channel locks; then you insert the paperclip.
illSHOyou
Troy, MO
Thanks Mr. A :)
