The SHOforum 12 second Challenge.
Sho Amo
SmkTyresntDrugs
Olney, Md
Well I want to scream and shout but I cant because im typing. All I can really say is FU(k YESSSSSSS
Oh, and it has more in it too.
Roughly ~13psi conservatively tuned, drag radials at 15psi, and no passenger or rear seat.
AndrewsTimeSlip4 3 11
Its going to go faster too. I guarantee it.
SHOspazz92
Banned
Triad Area, North Carolina.
VERY Well done!!!!!
Your the first on the list.
-Sam
Sho Amo
SmkTyresntDrugs
Olney, Md
And ill be damned, you called the time within a 100th of a second. I think next time ill leave the interior in. I didnt really take out much so I dont think it was worth it.
I wanted to blow it up so I had a reason to go forged. I dont think I did, but ill do a compression test next sunday to see whats up. After that I need to get that quaifed trans from justin and fix my parking brake so I can get those tires warmed up much better. This car has a record setting run in it pretty much how it sits.
Sho Amo
SmkTyresntDrugs
Olney, Md
Second time that set of tires has been in the 12s. Thanks James :)
Edit: heres a video of my last run. Its the only one ive got and it was a 13.5@111, for some reason misfiring through second.
Th VIDEO0003
whiteguy3
Scott MacIntire
Silver Spring, MD
The car has more no doubt! Getting this thing into the 12's has been fun. I think with the same boost we could eek out a 12.5. And I do believe a quaife would help in the 60ft department. It was one wheel burn out all day. A 2.0 60ft alone would net 2 tenths.
I think the misfire was a coil that popped out and missed for second. This will be corrected. The coils have been extremely reliable.
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
The 60ft explains the MPH. I wanna see you flicker the bottom bulb (shallow stage) and run that ***** for all its worth. I see a 12.6x in it for sure.
