zeus268
Maple Leaf SHO
A hint for you colder weather climate owners....
Take a hair dryer, or heat gun and warm up the plastic a bit, just enough to make the plastic more pliable rather than brittle and prone to breakage.
..... and don't just go tug'n on stuff..... look at where those tabs are located and be gentle when applying any type of force.
Typically you won't need all that much to bend in those tabs in order to remove the entire piece itself.
Happy Modding people![]()
Good tip. I figured that when I have the lower grille removed from the car, it would be a better opportunity to see where the plastic "tabs" are located for removing the cover. I didn't want to blindly tug of the cover and break anything..... I'm far too careful for that
Andrew and
