SHOstopper1992
Whoops
I don't understand why some people end every sentence with an ellipsis...
Its a bad habit of mine
That's good to know. Loooking at getting a set of slicers widened to either 7.5" for a 215 tire, or out to 8" for a 225 tire. Might just go with the 8", which could work with the usual fener lip trimming on an '89.
.That's good to know. Loooking at getting a set of slicers widened to either 7.5" for a 215 tire, or out to 8" for a 225 tire. Might just go with the 8", which could work with the usual fener lip trimming on an '89.
#1 See if you can find a place to redrill the stock hubs for you. You're in the Charlotte area after all...
#2 depends on the offset of the wheel and even what brand of tire you're going to run...
I run 225/55/16's on slicers. Getting them widened would not be worth the money if you ask me, so much easier to buy a aftermarket rim and call it a day
I think you're aware but you'll need to run spacers and probably longer lugs becuase the material is only added to the inside. I wouldn't mind a 16x8" Slicer.
Back on topic, I can think of at least two Gen 2 SHOs with 17x9s.
18x8.5's here, had to do some minor trimming on the fenders (GEN I). If you get the perfect offset, you can make it work.
225 is WAY too wide for a slicer. In fact, the stock 215s were marginally too wide. I run 215/45/17 on a 17x7.5" rim on the LGT, and that is perfect. I run street pressures on the track, and the tires all wear evenly, even with -2 of camber.The car came with 17x7" with the 215s, and the increase of the 1/2" of width is noticeable in handling and steering response.
225s are perfect for an 8" rim. Learned that the hard way on the 911 many years ago.
First off, comparing tire capabilities between a FWD sedan and a rear-engine RWD sports car is like comparing an airplane to a boat. They both move based on fluid dynamics, but (beyond that) what applies to one isn't the same as the other.
The factory designation for P225/55R16 tires show the wheel design range of 6"-8" with 7" used for measurement purposes. Here is what Tire Rack states about the rim width range.
Rim Width Range
Because tires have flexible sidewalls, a single tire size will fit on a variety of rim widths. A tire's rim width range identifies the narrowest to the widest rim widths that the tire is designed to fit. The width of the rim will influence the width(section) of the tire. A tire mounted on a narrow rim would be "narrower" than if the same size tire was mounted on a wide rim. NOTE: Because the overall diameter of a steel belted radial is determined by the steel belts, there is little, if any, change to the overall diameter of the tire due to differences in rim width.![]()
Different tires yield different results, my hankook's which were 2 ply and where compossed of nylon and poly handles so much better in the corners with less tread squirm compared to my continental extreem contact DW's with a 1 ply poly sidewall
