Widest Wheels
North Carolina
I'm talking to some buddies about doing wheels on my SHO and have had a **** of a time with trying to figure out what to go with.
Just curious, what is the widest tire size run with/without rolled fenders, and the widest rim run so far?
mrecoolgar
SHO NUP
Hershey-PA
These are 17x7.5, 42mm offset with 225/50/17.
Close but no interference.
kevinspann
Don't take my advice.
Richmond VA
Whatever x 8 is the widest you can probably go. Sam was 17x9 but they stick way out of the fender.
My 17x7.5 are quite close to the strut (Has 235/45/17 on them, cannot go wider), but I don't know the offset.
North Carolina
I am gonna be doing a lug conversion adapter plate which is about 25mm wide. Then i am gonna roll my fenders. I wanna try and run a 17x9 all the way around if its possible...
mosho93
Well-Known Member
Wausau, WI
Hope you don't care about your paint on the side...These tires are going to stick out a lot!
kevinspann
Richmond VA
Uhh. Good luck. Hopefully there are recesses in the back of the wheel to fit over the factory studs too. I dunno about 17x9s...also they'll be useless in the rear.
Phoenix
SHOHOLIC
QC , Canada
18X8 and you cant put a finger between the shocks (rear) , plus if you are lowered a bit , you will need to roll your rear fenders (with +38 or 40 offset)
Remember the offset is as important , to check if it fits.
North Carolina
What I am thinking about doing is ordering the rims and the adapter plates, and then Test fit them. Then I will find out what has to be done...
I plan on having rolled fenders...
DJSHO91
Durham, NC
My wheels are 17x7.5, with a 38mm offset, and running a 225/50 tire. I've done some trimming and grinding on the inside rear wheel lip, but still getting some rubbing when they bottom out. Probably do some rolling when I get a chance. :salute:
zach44102
BIG TURBO
Georgia
running a 225/45 or 225/40 should fix that.:)
RonPorter
SHO Club of America
Lake Orion, MI
That's good to know. Loooking at getting a set of slicers widened to either 7.5" for a 215 tire, or out to 8" for a 225 tire. Might just go with the 8", which could work with the usual fener lip trimming on an '89.
crystizel
