91PDXmocha
Thanks for posting and the info Jon .
sounds like you have a nasty miss fire in that video. what did that end up being?
Why waste ur time wit 30s....
Waste your time with free parts I had in my garage ? Opposed to spending 400$ on new injectors you mean ? Plus I can use all the time to learn turning .
Waste ... I don't think so .
Why waste your time s/c a Taurus ?
I plan on getting 48's after upgrading the Maf next .
Mustang forums eBay they are always popping up, they always upgrading.
How do you make the mustang injectors work? I thought the tips were different on the flow side of the injector "fuel side" ? And what was the air fuel with the stock injectors and meter, one more question, did you use the stock maf as a blow thru or draw thru set-up?? Thanks man and sorry for all the questions. Im used to working with 5.0 mustangs and turbos,, I have run a set of 42lb inj. with a calibrated maf meter and never touched the computer on a 5.0 mustang. And the idle , and street manners was perfect. The fuel pressure was manual adjusted to 42psi from the stock 38-39psi and the maf meter was a pmas blow thru. car made 490rwhp with 2 small garretts. My a/f was getting lean at 5400rpm, but the motor made 311rwhp before the turbos, boost was set to 8-10spi ,,, so now I have a 95 sho and looking to run a single turbo on it. This is a good write up a turbo sho build, toolman's is awesome too! Thanks for any advice you can throw my way-
Second thatYou need to get some vids up!
Second that
