PDX's first Turbo 91 Mocha
Jh8990
New Jersey
rod shifter, and the plus hood :)
91PDXmocha
Portland , Oregon
does anyone have anything to say about the NGK AFX Wideband O2 tuner kit ? its just got the box with digital display but I can get it for 150 or less local. anyone ever used one ? what do I need to look for to see if it will work with my soon to be acuired tweecerRT ?
91PDXmocha
Portland , Oregon
*update* got a aem WB02 ordered from work should come in this week. Also ordered a oil filter sandwich to install a oil cooler and re-route my turbo feed line and pressure gauge. The SHO hangs right with maybe slightly slower then a friends lightly modded srt-4 thats running 13.8-14.0's at the track. Car still running good driving it to and from work. more updates this week when I get new parts .
91PDXmocha
Portland , Oregon
Well have been driving the T SHO for about 3k miles so far . Wanted to get some ideas on what do look at upgrading after my next mods.
Right now I am pretty up to date with everything new as far as seals/gaskets/brakes/susp. Have a cheap catchcan set up on order to replace my bottle.
List of next desirables (not in a set order yet)
Sho Nut FPR
add IAT sensor
MAF upgrade
oil cooler
2x drag radials
custom catback 3" single or 2 1/2 duals
Also going to start another ported intake
cleaned up heads with new seals
wavetrack after I grenade the current tranny and the 1st backup * knock on wood *
light 17" wheels
any more recommendations ? comments ? Thanks
91PDXmocha
Portland , Oregon
Yea I am hoping that going semi-easy on the clutch that it will hold up to the 5 psi for a little while before I up the boost, then put in a stage 3 and god willing a wavetrack at the same time.
91PDXmocha
Portland , Oregon
Isn't it tough fighting the urge to dip into boost? :evilgrin:
Ugh , all freaking day long... on the way to work, lunch , drive home . I really try not to be THAT dude driving around tachin it out to bark the BOV at every car / passerby ( like subaru owners ) . But its not for them...for some reason I just love this freakin old lame ugly whistling tore-ass :)
91PDXmocha
Portland , Oregon
Update - Been urgently waiting for this next set of upgrades :)
Got my Quarterhorse tonight ! Thank you to Pops Racing .
I picked up a large front mount intercooler local this week for 80$, and a spare laptop to run in the car for 120$. Cleaned my set of 30 lb'rs and put on new o-rings. Getting software set up tommrow hopefully, and making the new charge pipes and doing the injector install this weekend. Also going to take this time to install the AEM wideband ive had sitting at work .
I havent made a final decision on a MAF. If I have the money Im going with the HPX slot for sure. Right now I have a 73mm bosch blow-thu maf that I was going to see if its any way compatable, or just get a cheaper available 80-90mm unit .
Shooting for 300-325 WHP ,on 7-8 psi . Ill be getting it to the dyno this time after getting some help tweaking the tune. Going to see whatever I can get out of 85-90%DC on the 30's and expeirement with tuning before I get a set of 48's. Then the fun can really begin !
-lame stuff I need to change while Im at it , right side wheel bearing is starting to go, along with the LCA . Probably all the burnouts lately ha . Pics Soon !
Sho Amo
SmkTyresntDrugs
Olney, Md
Awesome, I gave up on tuning lol. Props to you for trying, im just going to have Adam do it.
Have you thought about changing turbos?
91PDXmocha
Portland , Oregon
Def thought about it and plan to down the road. Same thing I want to try and max it out before upgrading. Or blow it up ha . Will probably end up with a precision like your new pretty one next :)
