Name that Noise!
Enzo731
Montreal, Quebec
Well, I've been starting to get this noise now every time I drive about 10+ miles. You can hear it when I start to rev between 1k to 1.5k rpm.
To hear the noise thanks to my wonderful blackberry and because I was alone, you'll have to turn up the speaker volume and everything to the maximum to hear this noise.
Sounds like a rattle, or a knock.. Not really sure. Here's the link
http://www.youtube.com/watch?v=vlDh4IFbWl4
Thanks for any input.
Input about me taking another video of this noise is much appreciated as well ;)
kevinspann
Don't take my advice.
Richmond VA
OMG RODBEARINGS.
I honestly don't hear much in that video....does it sound like its coming from under the hood? You may have to make a video from the engine bay if it is.
shocar
shocrazy
Bend
I can't really hear it the video but you might want to check the torque on your main crank pully bolt. Mine back off on my 94 mtx once and it was a weird rattle.... Don't drive it until you check it. I think the torque is like a 130lbs but check the forum. I am sure there is a post about it.
SHO_ROLLER_2
Well-Known Member
Branford, Fl
Oooo......ooooooo
It's a Yamahammer right??
:p
Ditto on trying to get a vid from under the hood.
Enzo731
Montreal, Quebec
Thanks guys for the input. I've been hearing this sound for about a month now, and well I've still been driving and sometimes drive it hard.
I will have to continue this thread by posting a much clearer and more soundful video.
Enzo731
Montreal, Quebec
Just an update from today, I got the car warmed up and I tried to mimic the noise that I made in the video that is posted. Turns out if I rev the car in neutral, it will not make any noise at all.
But if i engage the clutch, it will make the noise in the video...Could it be a noisy throw-out bearing?
shocar
shocrazy
Bend
throwout bearing if its coming from the driver side. Does it it make the same noise when in gear or just in neutral?:. If the noise is coming from the passenger side, it could be the main crank bolt needs torqued as I mentioned before.
Enzo731
Montreal, Quebec
So far it does this when going into gear as well as neutral when the car is warmed up quite a bit and driven around. If it's left out for quite a bit without being driven it won't make this noise.
It sounds as if it's coming from both sides, it can be heard from both sides I think.
