My SHO
way2evil
ny
Finished a big project in my SHO. Check it out. Also had the windows tinted to 20% and the sun strip.
DSC 6387
DSC 6389
DSC 6390
Photo 1
DSC 6392
DSC 6400
Brett
SHOs before HOs
Minnesnowta
Much nicer then tossing a box back there to slide around as you drive. I like it.
mjhpadi
Pennsylvania
Very nice, did you make the speaker and amp enclosures yourself? They look great, and the install looks clean, nice work.
way2evil
ny
I had the box and amp panel made. The whole system was designed and built by one person. Yes they are the p3 slim subs and they hit hard.
SHOrod
Torrie Tuned
Cedar Rapids, IA
So do you have to pull the sub box out to access the air compressor/fix-a-flat, or is the bottom panel cut down to fit? ;)
-Rod
way2evil
ny
-Rod
That was actually the first thing we went over. The bottom panel was cut to the box so I can easily get to the spare without having to remove anything but that carpet.
Looks awesome! great job, and you still have ample room in that huge ass trunk! :dribble:
Thanks. The whole idea was to keep as much functionality of the big ass trunk as we could. That was the reason for the slim subs (which sound just as good as most regular subs).
North Carolina
I like it alot! Good work!
I dont wanna put my nose where it doesn't belong, but if you don't mind, how much did all that run?
Billm0066
Caliper Covers
USA
How was the power wire run through the firewall? Reason i'm asking because I was thinking of adding one small subwoofer to give a little more bass. Just one 10" sub so I dont take up too much room.
way2evil
ny
There was an unused grommet that went under the dash and then through the door sills to the trunk.
