Front clunk over speed bumps..?
cmwwit
PA
Hello, when i go over speed bumps in parking lots i can feel and here a clunk in my front end. If i go over them pretty slow it doesnt happen. Could it be subframe bushings? Whats the first thing i should check? Thanks..
zblackbeast
SHOtarded
Omaha, NE
Strut mounts, sway bar end links, ball joints, tie rods, strut rod bushing etc. the list goes on. The only way your going to know if by getting down there and messin' around some. Jack it up and put your hand at 12 and 6 o'clock and push pull in both directions to see if it moves.. if it does, ball joints, now go to 3 and 9 and do the same if it moves tie rods. Also while doing this also look at the strut mount to see if its moving around. Look at the sway bar link and make sure its tight on both ends and the boot isnt torn. Check the condition of all the bushings and joints. Look at the boots around the ball joint and sway bar link for cracks and seeps in grease! :)
GL
