Hey guys, I've got this leak. Where its coming from is somewhat of a mystery.
It only leaks when the engine is hot and starts very suddenly, leading me to believe that it will only leak when the thermostat is open. Could be wrong about that, however.
It's located on the passenger side of the engine bay on the back of the engine. It is not a heater hose. I know this because I disconnected both heater hoses that are located on the driver's side of the engine and led back far behind the engine and put on a bypass hose. The heater did not blow hot, but the leak came back the same as ever.
The coolant is dripping directly onto an O2 sensor located on exhaust pipe. I've removed the wheel and looked around in there, I cannot find a thing that could be causing this problem. Any ideas on what could be leaking? I've got to get this fixed ASAP!
I appreciate your time, guys! Thanks!
