SHO U Up, looks great! Thanks for the pictures, what type of paint did you use, wonder about those pesky bugs that plaster the front of our cars.....Have to really scrub them off sometimes...
2010 sho in platinum white.
Precision Automotive in richville, michigan matched color on lower cladding all around.
gives a " lowered " look w/out spring install.
their matching color on lower grill; turn signal bezels and painted portions of upper grill.
picking vehicle up tomorrow, will try to upload photos.
for anyone in mid michigan area Precision Automotive is highly recommended
tim
Anybody but me think the front grille needs to be changed or painted? My car is silver and I am thinking about painting the two silver bars black and leaving the chrome alone. Pictures? Thanks!
My car doesn't see alot of night time driving so my bug issue is kept to a minimum. Rocks are my enemy though. :laugh_ti: I do have some chips here and there now which aggravates me 'cos Ford said the car had this special paint to help reduce chips. Looks to me it will resemble the rest of my car's front ends over time. I would advise the new guys to look into the clear material for the bumpers/hoods for sure! And the paint I had my body shop guy mix for me. Sure beats going to buy that stuff from Ford or a paint shop.
Hey Tim, welcome aboard bud. I'm really surprised they painted that for ya. I was ready to get all mine done but was advised against it from several people, including my paint guy. That textured material is hard to paint and make paint stick to it. I weren't about to sand all that crap down either. Not including debris from tires hitting it and so on. I'm hoping Ford ends up color keying those in a couple years as I will go that route instead. Good luck with yours though, I bet it's gonna be bad ass for sure! Can't wait to see the pics!![]()
You can paint it successfully, but you have to use the correct adhesion promoter. Most of the cars these days use TPO plastic and that material takes a special type of adhesion promoter. If you use regular primer or paint right over it, it will peel off in sheets. I work in the business and my previous company was contracted by Ford to paint the fascias, rockers, and valance for the now extinct Lincoln LSE. That particular vehicle used RIM plastic and also takes a specific but different adhesion promoter. Either way, the parts are susceptible to chipping because of their location, but no more than the front fascia. I've painted other vehicles with this type of bottom trim...(the last being a Porsche Cayenne) and it holds up pretty well and is a very good look. It is definitely a fair amount of work if you do it properly though, and even more on a tri-coat car such as the White Platinum. You can't properly sand TPO either. The material gets "hairy" when you reach the substrate. You have to adhesion promote it, then if you want; a filling primer, sand it, and then you can apply your base and clear coats. The fill primer will make it more susceptible to cracking, but it will get rid of the grain and is a little better looking. I'd personally not fill the grain because of the reduced durability and with it being against the ground it's hard to notice it when it is body color.
Do you know the specific type of adhesion promoter in case I decide to take it in to get painted?
