stephen newberg
I agree with Paul. Even with a new battery the alternator output should be closer to 14v or higher when the car is first started.
pax, smn
pax, smn
Well the alternator/battery thing can be a vicious circle. Bad alternators usually will cause the battery to die which makes the alternators bad. Trying to charge a dead battery with the alternator will **** the alternator.
Did you take a close look at the wiring, especially the big ground from the megafuse block? The problems you describe with the humming through the speakers and the radio / other function buttons doing strange things are classic bad grounding symptoms. My wife's '97 and my old '96 both did things like this until I replaced power / battery wires. On my wife's car the entire charging system wire harness setup needed to be replaced, in my '96 it seemed to be just the small battery-to-fender ground. Also check your 2 engine-to-firewall ground straps. Hope this helps.
-Josh
