nope! i actually just closed the gap on my plugs a bit just because i stepped the boost up and since im running stock pistons i wanted to be safe. On 7-8 psi i was using the stock plug gap and not blowing out the spark.
just make sure you get them mounted securely. My first set would pop out and cause a misfire until i changed my setup.
btw what happened to your tranny? 3rd?
