A/C system = Blown
Wakeboy1337
GTPGTPGTPGTPGTP
Cape Cod, MA.
Summer just hit hard Sunday afternoon so I decided to press MAX A/C to keep the compressor running nonstop. Not even 2 minutes after doing so, I hear the sound you hear when a million beads fall on hard floor. and I see all of my A/C gas fly out from under the hood. I get home and compressor oil was all over (what a think is) the dryer, and all over the compressor. I finally get a chance to look at the car today and I cannot find a hole in the tubing or the dryer.(********* chamber is the dryer, right?)
This is an ATX a/c system btw.
I have some pics, as always
As you can see, the black paint has been ripped up by the pressure release.
DSCF5112
DSCF5113
I also noticed this, I It's attached to the compressor and has big ol' hole in the middle of it. Should it be like that?
DSCF5111
hawkeye18
Sorta cares
Norfolk, VA
The dryer/condenser is the cylindrical item mounted to the firewall; it has a two-wire electrical connector on top of it and the low-side fill port to the passenger side of it. I don't know what the death-star looking thing down there but it isn't the dryer.
The hole in the line doesn't look good - lines generally shouldn't have holes in them.
It's not on the firewall in MTXs. It's right by the compressor...yes...in the pic above.
Wakeboy1337
GTPGTPGTPGTPGTP
Cape Cod, MA.
:nut: I don't see a hole in my lines. :nut: Circle it for me :nut:
SHO SPD
SHO member #480
Naples, Florida
The last picture is your pressure relief valve. It is normal. BTW I need that line for MTX if anyone has one!! (the line with the pressure relief valve)
Edit, I dont see any issues with those lines in that picture. The noise was probably your compressor taking at ****. The flaking paint is normal, those lines go from warm to cold to wet back to warm all the time so its tough on the metals.
Wakeboy1337
GTPGTPGTPGTPGTP
Cape Cod, MA.
How do i tell where the failure point is, besides putting in more gas to see where it comes out?
I've done a compressor swap before, but We KNEW it was the compressor because it was leaking at the shaft seal.
Wakeboy1337
GTPGTPGTPGTPGTP
Cape Cod, MA.
Alright I went out and rotated the compressor by hand (the center, not pulley) and there was no Resistance from it what so ever. Is it safe to say I need a compressor?
hawkeye18
Sorta cares
Norfolk, VA
Yeah, I'd say it's toast.
In other news: This was my first thought upon reading the title of this thread.
"Looks like you blew a seal."
"No, no, it's just ice cream!"
