Car will not start... No spark.
walsh82
illinois
Car = 94 ATX 3.2
Hey guys, did a search and hate to add another thread to this symptom but I am having problems. As I said I did some searching and tried a few things that sounded like a similar situation.
First things first, 3-4 months ago, the car drove fine. Went to and from work with no problem. Started driving another car and it sat for 2 months before I needed to drive the SHO again, battery was dead, tried jumping and the car would not start for anything.
Finally have some time and help to work on it now so first thing I checked was all cables/grounds ect still in place, checked fuel pump emergency switch in trunk, friend tested to see if I had spark, no spark. Replaced the coil pack, nadda, replaced DIS, nadda.
Gave up for the night, but part store says next step would be crank sensor replacement and it is actually on order but from the reading I have done earlier today I have a feeling this is going to be a waste of another 75 bucks and a few hours of my time.
None of the threads I read ever had an absolute solution to this phantom starting issue, saw one guy ran his own wire from the coil pack to the fuse box and he was able to start the engine again.
So yeah I am basically hoping someone will know the solution before I go purchase this crank sensor tomorrow, maybe it is known now, I just didnt read the right thread. Who knows. I read 20-ish out of 2-300 found.
Any help would be great.
Did you put any Dielectric grease on the back of the DIS before you bolted it to the intake?
frosho
WOLFMAN
Tyngsboro, MA
Are you absolutely certain that the DIS is grounded? You didn't remove any brackets on the intake manifold crossover tube, did you?
Phoenix
SHOHOLIC
QC , Canada
X2 , if you install only 2 of the 4 bolts (even if they are tight as ****) it may not start. Happened to me.
So that ground strap NEEDS to be correctly installed.
frosho
WOLFMAN
Tyngsboro, MA
Is the PCM ground plugged in? There should be a small gauge wire coming off the negative battery terminal leading to a plug next to the strut tower.
The next thing I'd look at after that is the CCRM.
Phoenix
SHOHOLIC
QC , Canada
Well maybe its time you pull the codes , you might have a faulty sensor.
The ccrm has nothing to do with spark unless its not providing power to the PCM.
Phoenix
SHOHOLIC
QC , Canada
Bleh, ok, so finally got my CCRM in today and went to change it.
Took off old one and half the cable/ccrm was toast. Cleaned the
connector up best we could. Wires seem to be getting power good.
But still no fuel pump/spark.
Suppose as bad as the connector is there is a possibility the prongs
are not actually going in. But still if it fried the ccrm that bad just curious
if there is a chance anything else went bad I could look at.
I gotta say , you do not have a common issue.
Any pics of those burned wires?
EDIT: double check ALL fuses (inside and underhood)
SHOMON
95 MTX
MEDWAY MASS.
It will be the small 10a fuse in the under hood fuse panel. This powers the ccrm. I think it is labeled accy feed.
Phoenix
SHOHOLIC
QC , Canada
Definatly not normal , those burnt wires.
Did you replace the CCRM with a J code? Its very important that you have the correct letter. Theres 3 diff ones for the SHOs.
SHOMON
95 MTX
MEDWAY MASS.
Unplug the sensor that is in the coolant overflow bottle. When this sensor shorts out it will keep popping the 10 amp accy. feed fuse as soon as the key is turned on.
Phoenix
SHOHOLIC
QC , Canada
IIRC its an A/C relay , when I did my 2002 SHO , I ditched it.
And yes a cam sensor can prevent you from going anywhere.
