Car loses all power when trying to start, with video.
T.O_SHO
Power Hungry
Toronto, Ontario
Ya as Raff mentioned we bench tested the starter and it didn't have much movement... The solenoid wors fine but it baaarreellly spins...
Having that rebuilt and will report back with the outcome.
T.O_SHO
Power Hungry
Toronto, Ontario
Well, little update. Had the starter rebuilt, no dice. I did notice though the positive battery terminal was a little loose so I took it apart to clean it and notice inside it was corroded pretty badly. I replaced it with a new one onto a fresh piece of wire and the car hasn't ever started stronger :biggrin:
SHO_ROLLER_2
Well-Known Member
Branford, Fl
TOLD YOU TOLD YOU!!
:p
Glad it's up and running!:woo-hoo:
T.O_SHO
Power Hungry
Toronto, Ontario
:thankyou:
Yup, you guys said it... I'll be honest though the terminal looked fine. It was only until I pulled it off the wire did I see that it was corroded, badly.
