Mr95Gl
Mr Tire Iron
Don't mean to sound like a **** (since i'm asking for help and all), but please read the description before responding.
I've been trying to troubleshoot this issue on my 92 (91K) for several weeks now to no avail. The car will randomly misfire in all conditions. They include:
With or without rain
Cold or warm weather
With the car at operating temperature or on start-up
In all gears
It's the exact same type of miss in all of these conditions with no variation.
If it misfires, up until 2K in 1st it'll run fine. Between 2K-4K it'll buck back and forth very violently at times, and clear up above that. Sometimes, I'll feel it misfire in the upper RPM range but it's only happened a couple of times.
Some nights I'll drive to work (I commute 33 miles each way), and it will run perfectly fine (cold, hot, rain, dry). I'll intentionally hit a bump to see if there's a change in engine operation, but nothing. I'll drive back home from work, and no issues. I can go several days without any issues. Other times, it'll miss on my way to work, but not on my way back home or vice versa. Sometimes it'll miss half way to work, then clear up.
The car is not stock. It has the following:
PRO-M 80MM MAF w/ SHO Shop Can
BBB's
UDP's (3 piece)
Catless Y (cat relocated after Y) w/ 2 1/2 inch exhaust
69MM TB
Here's the maintenance history (currently sitting at 91K):
Timing Belt/Valve Adjustment at 62.5K
Fuel Filter at 73K
Plugs and Wires (Bosch) at 73K
O2 sensors at 77.6K
TPS at 77.7K
Crank and Cam sensor at 78K
I've tried swapping out the MAF for a stock one, removed the bosch wires/plugs and put back in APP3924 plugs with the original wires, swapped out the coil pack for 2 others, and DIS module with a spare. Also did a fuel injection cleaning. All of the grounds look fine.
I'm still getting the EXACT same misfire (when it happens) which leans towards none of those parts being the issue. Only thing left would be the TB, but would that cause an intermittent miss?
Here's a video of what happens when the miss occurs:
Any suggestions?
In all gears
BBB's
UDP's (3 piece)
69MM TB
Fuel Filter at 73K
O2 sensors at 77.6K
TPS at 77.7K
Any suggestions?
