'89 Freshly 3.2 Swapped - 35 Pics! ---Sale Pending---
Ocnaj
SHOcomotive
Pittsburgh, PA
I have posted this car before but it is now 3.2 swapped.
It's an '89 Virginia car that I did all the work myself on. The car is silver on gray and runs very well. It has a 3.2 swap with a welded MTX. The engine and transmission were completely went over before installation into the car and they are mechanically sound. It still needs a couple of things to be a solid car though. It's from Virginia and it is 99 percent rust free. The silver paint job was done sometime in it's past but I am unsure of when it was painted. The car's original color looks to be Titanium. The interior seems like it wasn't taken care of very well and isn't in very good condition. If you have any other questions feel free to ask. It is located in PA 20 miles south of Pittsburgh.
----PA Inspected until 4/2011----
All new gaskets and seals are Fel-Pro unless otherwise stated.
Engine:
3.0 Oil Pan
New Oil Pan Gaskets
New Oil Pickup Gasket
New Oil Pump Gasket
3.2 Oil Pump
New Front Main Seal
New Rear Main Seal Set (Includes Rear Main Seal and Rear Main Seal Carrier Gasket)
New Dipstick Tube Gasket
New Head Gaskets
3.0 Cylinder Heads w/ Brand New Head Bolts from Fel-Pro
New Valve Cover Gaskets and Spark Plug Well Seals
New Timing Belt
New Water Pump, Water Pump Outlet, and Thermostat Housing Gaskets
New Crossover Tube, Thermostat, and Water Pump Housing to Block Seals
New Cam Seals
New Fuel Injector Seal Set
New Throttle Body Gasket
New Exhaust Donut Gasket (Y-pipe to catback)
New Oxygen Sensors
Resurfaced Flywheel
Clutchnet Stage 2 Clutch Kit
SHOnut Ceramic Throwout Bearing
A/C Delete + Gutted Compressor
New Reman Starter
ALSFBs(Thanks James)
It runs very good and has alot of low end. I have been driving it to work with no problems at all. Hasn't burnt a drop of oil in the last 1500+ miles that I've been driving it.
Transmission:
New Axle Seals (National)
New Input Shaft Seal (National)
New Shift Shaft Seals (National)
Welded Differential Pins (No SHO Boom Here:))
Custom Cable Shifter Bushings
Shifts through every gear smoothly and doesn't grind.
What it needs:
Rear Struts (Has the typical rear end sag and the left rear makes some noise)
Radio and Speakers
Headliner
I will have more pictures up soon.
I am asking $2400 obo.
image.php
image.php
image.php
image.php
image.php
image.php
image.php
image.php
image.php
image.php
image.php
image.php
image.php
image.php
image.php
Ocnaj
SHOcomotive
Pittsburgh, PA
The diff that is in the car:
image.php
If anyone wants a picture of anything specific let me know and I will get it.
I will also have pictures of the undercarriage up on or before the weekend depending on when I get it on the lift.
Ocnaj
SHOcomotive
Pittsburgh, PA
I apologize, I forgot to mention this car seems to be a stripper model SHO.
No, the A/C was deleted when I had the drivetrain out.
Here are some interior pics:
image.php
image.php
image.php
image.php
image.php
TimboSHO
Intermediate
Wyoming, MI
Doesn't look like a stripper to me. Has Auto Climate control, auto headlamps, power antenna, keyless entry and premuim sound. The only options it's missing is full leather, moonroof and power passenger's seat. Am I correct?
Ocnaj
SHOcomotive
Pittsburgh, PA
Yeah you got it. Show's you how much I know about SHO options...
So there are SHOs that came with non-power antennas?
Ocnaj
SHOcomotive
Pittsburgh, PA
More Pics and Update
Ok guys, I installed ALSFBs (Thanks James).
I also took pictures of the undercarriage and a couple of other things.
Don't mind the oil/grease on the subframe and other places that's from the original 3.0 that leaked everywhere.
image.php
Original Ford Mufflers
image.php
image.php
image.php
image.php
image.php
image.php
image.php
image.php
ALSFBs:
image.php
image.php
image.php
image.php
To show the webbing on the 3.2 bottom end:
image.php
kvm101
Allentown PA
The 3.2 motor had how many miles before swapping over 3.0 pulleys etc. ? Whats causing the oil on the undercarrage ?
Lastly inspected? Didnt notice any window stickers.
89 SHO restored driven hard (sold)
93 SHO atx chased oil leaks trans out twice agh
Looking for a III gen but wanted to swap out my 93 SHO 3.2 it was beat from previous owner. I shouldnt say beat oil changes every 7k from Kmart. Gave me paper work after the sale thought cool maintanence records. One day bored I read through them (yikes)
Ocnaj
SHOcomotive
Pittsburgh, PA
The 3.2 that I put in had around 70k miles. The mileage was recorded by the salvage yard 'Sechrist Used Auto & Truck Parts' in Dawson, PA.
The oil on the undercarriage has nothing to do with the fresh 3.2. It's from the 3.0 that used to be in the car and I just never got around to cleaning it off. Both the transmission and the engine don't leak one drop of oil/fluid.
I forgot to add that the car is PA inspected until 4/2011.
Ocnaj
SHOcomotive
Pittsburgh, PA
Ok guys, I'm lowering the price down to $2500. I know it's not much but I need to sell this car sooner than later. Don't be afraid to throw me some offers.
Also, how do I change the title of the thread?
313tiger
