Car loses all power when trying to start, with video.
T.O_SHO
Power Hungry
Toronto, Ontario
As you can see in the video, as soon as I turn the key to start the car, I'll lose all power and sometimes the starter will click, as you can faintly hear. Most times after trying to start it the clock will reset to 12:00 and I'll lose all radio pre-sets. If the key is in any other position I have normal power to everything.
Th  IMG 0030
It did this a couple months ago so I checked the ground on the fender, cleaned it and re-attached it and also replaced the starter solenoid. It's been fine since, but now it's doing it again. Does this sound like a familiar problem? I can bump start the car no problem, but really hate doing so. Battery is fine, checked with voltmeter and also checked the alternator when it was running and it was putting out over 14 volts.
I've read from past threads it's most likely a grounding issue, but I only know of the ground on the fender, and it's fine.
Any help is appreciated :thumb:
firebat45
Edmonton
Clean your battery terminals? You could check the ignition switch too to figure out if the problem is before or after it, but that's more work.
LJRuddy
Pop lock n drop
Poaceae fields
My car does that same thing if you fail to depress the clutch pedal. Maybe the clutch switch is bad? Just a thought from another perspective...
T.O_SHO
Power Hungry
Toronto, Ontario
The signs lead me to believe it's something not so simple. The radio and clock resetting is something that tells me it's definitely electrical related.
hawkeye18
Sorta cares
Norfolk, VA
Every time I've lost power when trying to crank (and it has been many times), it has been poor contact at the battery terminals. In my last case, the terminal had actually cracked on the inside and wasn't clamping at all. It is something you might want to look into.
the4biddendonut
Hurry up meow.
Elk River MN
I'd have a load test done on the battery. Just because the battery reads the correct voltage doesn't mean it's a good battery. It's just another thing to cross off the list.
T.O_SHO
Power Hungry
Toronto, Ontario
I will look closer at the battery... I'll also try swapping it for the one in the Mustang, see if that makes a difference...
Thanks guys :thumb:
T.O_SHO
Power Hungry
Toronto, Ontario
Turns out it was the battery :thumb: :thumb:
Tried it with the current battery, nothing... Swapped for the Mustangs battery and it fired right up...
Thanks for the help guys :thumb:
hawkeye18
Sorta cares
Norfolk, VA
Ok so I wasn't right on the money but at least I was close. Glad we could help!
T.O_SHO
Power Hungry
Toronto, Ontario
It's doing it again. :ohreally:
All day yesterday it was fine, today it was pouring rain and wouldn't start, just like in the video. Brand new battery too.
Ishodu
Try moving your battery cables around a bit. Some times they rot away from the in side. Also check them where they connect to the starter.
SHO_ROLLER_2
Well-Known Member
Branford, Fl
Check/change the POS battery cable.
Mine was grounding out and eating solenoids because of it.
Check the whole thing. On mine, the cable was showing UNDER the plastic cover so it looked fine until I removed it and had a good look.
I'd check the contacts on the starter as well.
SHO SPD
SHO member #480
Naples, Florida
Check the resistance in the battery cables also, sounds like you have a bad cable, and moving it around changing the battery effected it.
T.O_SHO
Power Hungry
Toronto, Ontario
Thanks.
Is that something I can test with a multimeter? I can truthfully say I'm not fond of electrical work :biggrin:
SHO SPD
SHO member #480
Naples, Florida
Haha, Yea test it with a multimeter. Set it to ohms and put one lead on one end of the cable and the other lead to the other end. LOW Resistance it what youre looking for.
