Coolant Leak
goalieman59
Learning Slowly
OFallon, IL
I am going to get a set, so if I need them then I have them. If not I can return them. I am hoping to get to return them.
jmpSHO
Massachusetts
Why exactly?:munch:
Gman, if the gaskets look good you can reuse them. How old are they? Originals? Have you replaced them before?
That's my opinion of any gasket unless it was replaced recently or not available in the auto parts store.
TYSHO
Earth
You mean the heater hoses that I mentioned? ;)
Nope, you said the two hoses going to and coming from the heater core that are up top in the engine bay by the firewall. The one I am talking about is a very short, fat hose often overlooked and unknown from being hidden down under all the wiring and whatever else you want to call it. ;)
silver93sho
I hate that bugger!
silver93sho
you outta figure out whats leaking first before you go looking at random coolant hoses. That larger one connects the coolant housings between the 2 heads. IF it is that one you need like 1 1/2in of hose, 2 clamps and unbolt the thermostat housing and coolant housing on the rear head as one to replace it. Which also undoes your cross tube from your WP and so on so id find the leak first!
silver93sho
I dont want to argue over a post so if they arent worm gear type clamps(meaning someone at some point changed them out) then get you some new hose and clamps and have at it!
