turbo SHO vs E85 compression
SHOmethewayhome
BAD ROLE MODEL
Saint Paul, Minnesota
Put Donovan in the passenger seat for front ballast to keep the tires down Tom! (assuming you're talking about the other woman).
I need to take that ride!
BlackonBlack89
burlington county,NJ
Related note.
Are they any negatives to E85?
And does it affect anything thats on the stock fuel setup. IIRC it degrades the rubber lines, which could clog an injector. maybe thats something else.. I forget.
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
should we start taking bets on what breaks first on the engine. There are only 4 other things left to break.
head gasket due to lifting heads under power
rods
crank
block
When you break 3 out of the 4 of those, we've got engines we've been prototyping for awhile now that will solve the issues.
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
Keep an eye on spacecoastspeedshop.com. Been busy with opening up and getting the website going and all. Once things smooth out I'll have time to post pics and all and have prices. Cheaper than a typical wiesco build and we have solved the rod bearing issue associated with these engines.
somedude_001
Western NY
I was looking at 120lb for my camaro build. Think that is too big? a separate feed for each fuel rail to a common regulator. Start with 1 255lph pump with the possibility of adding a second later on.
92sho16
b00sted
Liverpool, NY
sho_sc
Georgetown, KY
